Old 11-27-2023, 10:52 PM   #1
mkoot
Drives: low black brz
Unhappy oil catch smoke and leak
after installing oil catch can i found location of leak i took the top of the intake manifold off and the whatever from back below it and tons of white smoke and dripping burning oil on the front of the exhaust where i hadnt worked. i did run the car and some revs for warmup because i didnt notice any leaks or smoke at first. fixed the order of the hoses and it did again, leak oil only when its running.
mkoot is offline   Reply With Quote
Old 11-28-2023, 02:53 PM   #2
mkoot
Long day problem solving I was tired and that made little sense. I added a lil catch can but it didn’t work well, I uninstalled it and replaced my old pcv hose, now when I turn over there is oil over the headers and smoke from exhaust (white).. no hose leaks it seems but my other hoses are shaking a lot more than it seems it was
The Following User Says Thank You to mkoot For This Useful Post:
x808drifter (11-29-2023)
Old 11-29-2023, 06:40 PM   #3
Grady
Grady's Avatar
Was the catch can installed to fix a problem or preventative? Catch cans do not fix problems. Is it working now? I can not decipher your posts completely.
The Following 2 Users Say Thank You to Grady For This Useful Post:
x808drifter (11-30-2023), ZDan (11-30-2023)
Old 11-30-2023, 10:00 AM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
^^^ This is my question as well: "Why a catch can?"
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Grady (11-30-2023), Teseo (12-03-2023), x808drifter (11-30-2023)
Smoke dpfarr Engine, Exhaust, Transmission 8 12-19-2021 10:15 PM
Smoke from engine bay due to oil leak? boksajak Issues | Warranty | Recalls / TSB 9 11-26-2020 02:26 PM
The Smoke Leak Test - Why We Use it, and Why it Works Circuit Motorsports Engine, Exhaust, Transmission 0 06-04-2014 04:37 PM
Smoke? zoomzoomers BRZ First-Gen (2012+) — General Topics 20 02-08-2013 07:06 PM
Plastidip Smoke Sutty Cosmetic Modification (Interior/Exterior/Lighting) 1 09-29-2012 05:04 PM
