Old 11-13-2023, 11:12 AM   #1
gshopper
Drives: 2003 330i, 2019 BRZ (blue, with PP)
replacing blown FA-20. What options to get?
Forgive crosspost please.
A few weeks ago, I posted about my 2019 BRZ which blew up its engine at the track. Probably threw a rod, but I won't know until they pull the engine. It was stock except for an oil cooler, JDL 4-2-1 header, flex fuel kit, and a tune from a prominent East Coast tuner. Although it's not clear what happened, it was probably not oiling, as the motor was strong up to the point it grenaded. ?Maybe the tune??
I have a short block on order, and it should be arriving soon. The block is OEM, and I will have the header and flex fuel kit reinstalled. I'll probably get a tune from CSG trying to prioritize longevity over power.
Does anybody have suggestions for anything to do while we are doing this? I've committed to an OEM block, but maybe Killer B oil pickup? worth it? I'll have them check the clutch. Anything else to do?
Thanks in advance.
gshopper is offline   Reply With Quote
Old 11-13-2023, 12:28 PM   #2
tomm.brz
Drives: brz 2017 hksv2
you really need to ruin on purpouse the tune to make it grenade while on NA the ecu just corrects a lot and is difficult to make damage
just unlucky
Old 11-13-2023, 08:36 PM   #3
just unlucky
Corrections are reactive. To correct, there must first be something to trigger the correction.
Poking your skin with a needle once, will likely to zero damage. Poke the same location 1000 times, and you will have permanent damage.
Old 11-14-2023, 08:01 AM   #4
tomm.brz
of course
what about stock tune and 91oxtane? it knocks constantly.
he is NA , and running ethanol mixture, how much do you think it would knock/correct? and even if it does, not so different than a stock tune with 91oct /95 ron or worse, and subaru says is ok
engine, fa-20
Replacing blown FA-20. What options to get? gshopper BRZ First-Gen (2012+) — General Topics 14 02-03-2024 07:26 PM
Boosted Blown Motor Options, Should it Happen Chad86 Forced Induction 25 10-14-2015 12:49 PM
Options for replacing the Limited's spoiler Flow Cosmetic Modification (Interior/Exterior/Lighting) 15 02-10-2014 12:12 AM
Scion FR-S options:what options did you have dealer installed? Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 42 01-06-2014 01:35 AM
Bushing upgrades, geometry options and other component options? der_rainman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-26-2013 12:53 PM
