Old 07-22-2011, 03:30 PM   #1
Abflug
Abflug's Avatar
Drives: MR2
Question MR2 owners - suspension experience
Hi,
I am thinking about to upgrade my suspension with some Bilstein shocks and Eibach springs but I donīt want a too stiff setup because of my harassed back
What are you experience with this setup?!
Would you recommend it or would you prefer others?!
Abflug is offline   Reply With Quote
Old 07-22-2011, 03:38 PM   #2
john
john's Avatar
Drives: 2003 Honda S2000
There are a quite a few MR2 owners on this board who can probably help you out. Your car has a wide selection of aftermarket support so don't rush it and choose carefully.
john is offline   Reply With Quote
Old 07-22-2011, 03:55 PM   #3
Abflug
Abflug's Avatar
Drives: MR2
donīt worry! I drilled down the market for a while, I just need some empirical values!
Old 07-22-2011, 05:39 PM   #4
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
im currently on just Tein S.tech springs and the ride is pretty comfortable.. though ive never been in an mr2 with eibach springs, ive been in my friends honda with eibachs and the ride is hella rough
VenomRush is offline   Reply With Quote
Old 07-22-2011, 06:49 PM   #5
Abflug
Abflug's Avatar
Drives: MR2
hm...I heard the opposite! Isnīt it that teinīs are stiffer?!
Old 07-22-2011, 06:58 PM   #6
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
Coilovers out of your budget?
Neutral_Eyes is offline   Reply With Quote
Old 07-22-2011, 07:04 PM   #7
Abflug
Abflug's Avatar
Drives: MR2
^^I donīt understand your question!
Old 07-22-2011, 07:36 PM   #8
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
hearing and feeling are two different things... but i did just remember that he had the eibach *edit* sportline
Old 07-22-2011, 07:42 PM   #9
Abflug
Abflug's Avatar
Drives: MR2
Old 07-22-2011, 09:22 PM   #10
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
also, over at the mr2 forum, people seem to be content with koni yellows. ive driven an mr2 with gr-2 struts which were a little too stiff for my tastes.. i guess what im trying to say is, go with what you feel based on reviews and hear say. if you're not mixin and matching different set-ups, then you're not really lookin for a good suspension set
Old 07-22-2011, 09:47 PM   #11
speed-wiz
speed-wiz's Avatar
Drives: MR2
I've used Eibach Prokit and Sportlines on my MR2s, which have all been 1993 or later.
The Prokits are not much different from stock, slightly stiffer and just barely shorter. The Sportlines are a good bit lower and somewhat stiffer but not bad at all.
I've had good luck with Bilstein shocks on MR2s. They're firm but comfortable.
speed-wiz is offline   Reply With Quote
Old 07-23-2011, 01:24 AM   #12
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
I like it rough. Can't help you out. Sorry.
Midship Runabout is offline   Reply With Quote
Old 07-23-2011, 06:13 AM   #13
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
I had Bilstein HD (same part numbers printed on the discontinued TRD struts) with TRD springs. It was noticeably stiffer than stock and while I liked it, I can't imagine anyone with a bad back enjoying it. Keep in mind if you lower your car you'll need stiffer struts for lastability. The lower you go, the stiffer the struts you'll need; it's up to you how much you want to your back to suffer.
Bilstein HD stiffness is overkill for this car (the HD line is used mostly for trucks). I recommend Bilstein TC struts if you can still find them. They came standard from the factory on the late model year JDM models (sometime around '96-'98). I'm not sure how well matched they are to springs shorter than OEM from those model years but do a search on MR2OC.com; some people there had those struts.
Old 07-23-2011, 02:26 PM   #14
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
what's your budget?
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Any MR2 owners here? MF_DEUCE Scion FR-S / Toyota 86 GT86 General Forum 31 12-06-2012 11:24 AM
Front Suspension 'discovery'? Dimman BRZ First-Gen (2012+) — General Topics 13 07-23-2011 08:22 PM
any other Mazda rx7 owners here? millertime Other Vehicles & General Automotive Discussions 12 05-26-2011 07:51 PM
Lets talk suspension Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 42 05-20-2010 12:51 AM
Stock suspension adjustability? #87 Scion FR-S / Toyota 86 GT86 General Forum 4 01-02-2010 04:36 PM
