Old 10-30-2023, 01:43 PM   #1
Alfrz
Drives: 13 Scion Frs
ABS/Traction lights after replacing EPS Dampener
So I finally replaced my EPS dampener last night, and the rattles all gone
My steering wheel came all the way out during the process, and it took a lot of finagling to get it back in. It now sits at a slight angle when driving straight.
***Most importantly, how dangerous is it to drive the car with these lights on? Am I going to cause more damage?***
During my test drive afterwards the ABS/Traction lights came on(was right after a bump, but only 1minute into the drive. Not sure if the bump has anything to do with it but I figured I'd mention)
From what I've read online it's the steering angle sensor (or only needs to be calibrated?) or the clock spring broke.
-Isn't the steering angle sensor just inside of the clock spring? As in, is just buying that part simpler? There's some for very cheap on eBay.
-For calibrating, I keep seeing TechStream, is that something that it's worth it to buy it online for JUST this? or is it something to just go to a dealer for(would smaller shops carry this?)
-Is this a simple enough/become cheap enough job to buy Techstream + Clockspring and do it myself?
Literally any input is helpful and I'm really early on in the process of reading all the stuff, but these are a lot of new words and parts here for me, so any help is appreciated
Added codes C1231
C1234
C1241
C1249
C1294
Alfrz is offline   Reply With Quote
Old 10-30-2023, 03:52 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Check out related pages in the service manual. See link in my signature line.
Old 10-30-2023, 04:05 PM   #3
Alfrz
So I actually saw your post on a previous thread, but I'm not even sure what I'd be looking for here. Power steering system calibration? Or were you pointing me at something else?
Just got the codes read
C1231
C1234
C1241
C1249
C1294
Old 10-30-2023, 09:54 PM   #4
Ultramaroon
not playing cards
C1231
C1234
C1241
C1249
C1294
Ah! I had to learn this lesson again! Duuuuhhhh...
These aren't power steering fault codes. They are related to VSC. Vehicle Stability Control (nannies) are in a weird section of the manual because that control unit lives in the ABS module.
This should help
Old 10-30-2023, 10:10 PM   #5
Ultramaroon
not playing cards
Are all those codes current? Feels like maybe the battery was left connected while working on it.
Clear codes and try again I bet you just need to straighten out your steering wheel and do the yaw sensor calibration.
Traction, ABS and CE lights on Abdullah-1997 BRZ First-Gen (2012+) — General Topics 4 07-12-2021 11:41 AM
ABS and Traction Control lights on SOS wdmo Issues | Warranty | Recalls / TSB 7 02-17-2021 12:33 PM
Fuel pump squeak sound dampener? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-01-2018 09:25 PM
Replacing Gauge Cluster Lights Zan Southwest 2 04-15-2015 10:09 AM
Hood sound dampener Brimford Cosmetic Modification (Interior/Exterior/Lighting) 4 01-17-2013 08:00 PM
