Old 10-28-2023, 02:29 PM   #1
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
Replaced Key Battery, Now It Doesn't Work
2014 base model FR-S with standard key. Original battery approaching 10 years old, door/trunk lock function (using the buttons on the key) was starting to work intermittently. Replaced battery (2016) with a new one, now NONE of the key functions work.
Looked at a bunch of YouTube videos that claim that the key has to be re-connected to the car by inserting/removing key 4 times and then leaving it inserted in the ignition switch, then opening & closing the door 6 times. The security system light does go out when the key is inserted into the ignition switch, but still can't lock/unlock the doors or open the trunk with the buttons on the key.
There's NOTHING about this in the owner's manual- it just walks you through replacing the battery and says nothing about needing to do anything else.
Am I going to have to take it to the dealership and cough up $100+ for them to spend 30 seconds doing some magical pedal dance or some such?
Thanks
FlamingRectumSyndrome is offline   Reply With Quote
Old 10-28-2023, 03:05 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Thanks
No. Something else is wonky. Does the LED flash? If yes, some component for the transmitter may have fried when it was apart. Static charge? Semiconductors are super vulnerable. Don't need a spark to kill a diode or transistor.
FlamingRectumSyndrome (10-28-2023)
Old 10-28-2023, 03:50 PM   #3
tarzan_nojane
tarzan_nojane's Avatar
Drives: 2014 FR-S
I would check the voltage of the "new" battery with a voltmeter. No guarantee that the battery is good, especially in these specialty sizes.
The car computer memorizes as many as 3 transmitters. Nothing you can do with the key that will change the transmitter characteristics or make the computer "forget" a key.
tarzan_nojane is offline   Reply With Quote
The Following 4 Users Say Thank You to tarzan_nojane For This Useful Post:
FlamingRectumSyndrome (10-29-2023), humfrz (10-29-2023), Spuds (10-28-2023), The Red One (10-28-2023)
Old 10-28-2023, 04:37 PM   #4
The Red One
Pro Couch surfer
The Red One's Avatar
Drives: 2019 BRZ Sport-tech RS.City car:GD3
I second a faulty one due to old battery shelf life.
try a new battery from a different store .
Make shure there is no plastic tab protector stuck on the battery as well..
The Red One is offline   Reply With Quote
The Following User Says Thank You to The Red One For This Useful Post:
Spuds (10-28-2023)
Old 10-28-2023, 04:46 PM   #5
Ultramaroon
not playing cards
In my experience with low cells in my fobs, the LEDs always quit flashing whenever the transmitter wasn't working. If the LED flashed, transmitter power was adequate. As the cells neared death, I found I could get the transmitter to work by first holding the button for a couple seconds before trying again.
Pro tip: NO, it will NOT help to push harder on the buttons.
MJones_RB (10-30-2023)
Old 10-29-2023, 01:18 AM   #6
humfrz
Well, it used to! -
Old 10-29-2023, 02:47 AM   #7
Ultramaroon
not playing cards
Well, it used to! -
You're my target audience.
humfrz (10-29-2023)
Old 10-29-2023, 06:40 AM   #8
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
My hammer says otherwise.
The Following 2 Users Say Thank You to x808drifter For This Useful Post:
M&M_Hwy9 (11-02-2023), Ultramaroon (10-29-2023)
Old 10-29-2023, 08:15 AM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
My car beeps and I think something shows on the dash when the fob battery is low... But I could be wrong as I can't remember now.. it's been a few years since I changed the battery.. Oh fuck it, let me get over the 'jet lag' having lost/gained 1hr...
The Following User Says Thank You to JD001 For This Useful Post:
Old 10-29-2023, 03:35 PM   #10
Recording here for posterity, should anyone else have a similar issue: it is entirely possible that a factory sealed package of batteries can have sat in a drawer in your garage for so long that they still show a 3 Volt charge on your Fluke voltmeter, but have lost enough power that they don't produce enough amperage to operate the key functions.
Fresh batteries, folks. Don't be a cheap b@$+@rd like me.
The Following 4 Users Say Thank You to FlamingRectumSyndrome For This Useful Post:
JD001 (10-30-2023), Overdrive (01-02-2024), Ultramaroon (10-29-2023), x808drifter (10-30-2023)
Old 10-29-2023, 06:38 PM   #11
humfrz
OK, so I'll just keep banging it on the table -
Old 10-29-2023, 06:47 PM   #12
humfrz
Where did we start going wrong?
The Following 4 Users Say Thank You to humfrz For This Useful Post:
bcj (10-30-2023), blsfrs (10-29-2023), Overdrive (01-02-2024), Ultramaroon (10-29-2023)
Old 10-29-2023, 10:04 PM   #13
Ultramaroon
not playing cards
Are we still talking about key fobs?
humfrz (10-29-2023)
Old 10-30-2023, 12:04 AM   #14
humfrz
Oh, KEY FOBS ....... just put a new battery in them.
JD001 (10-30-2023), Ultramaroon (10-30-2023)
2013 BRZ won't turn over replaced starter, battery, st cut relay dewittk Issues | Warranty | Recalls / TSB 23 11-07-2024 12:47 PM
Good battery for car that doesn't get much use? covance Issues | Warranty | Recalls / TSB 18 02-11-2019 04:52 PM
Battery died under warranty - Dealer replaced rkaywhodat Issues | Warranty | Recalls / TSB 16 12-31-2018 03:16 PM
Car doesn't start without fully charged battery. frsq5 Issues | Warranty | Recalls / TSB 6 06-09-2017 09:59 PM
Toyota replaced battery with group 26R?! Mikeez Electronics | Audio | NAV | Infotainment 6 02-06-2017 10:27 AM
