Drives: White Subaru brz
Hey guys I could use help with a code
My 15 brz is having an issue with code P2109 on. I have already tried a test throttle body and PCM. Neither fixed the issues. I have tried using my OFT to clear the code and disconnecting the battery. Neither will clear the code out. The engine revs to 1500 rpm and I have no throttle response. Thanks for any help.
Drives: 2013 FR-S 6 spd in Halo
P2109 Throttle/Pedal Position Sensor A Minimum Stop Performance
"Sensor A" means that the DTC is referring to a particular sensor, which in this case could be the TPS or the pedal position sensor. Since it sounds like you have a source for donar parts, I would try swapping the PPS next. Otherwise, you need to get your hands on wiring diagrams/pinouts for the TPS and the PPS and start checking resistance through them. Go fast, take chances. |
#3 | |
| Hey guys I need help with a code | Loganp98 | Issues | Warranty | Recalls / TSB | 7 | 11-01-2023 08:07 AM |
| DIY - Color Code of ID plate and code of part (SUBARU) - SB18-091 | Trap63 | DIY (Do-It-Yourself) Guides | 0 | 06-14-2018 04:52 AM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 08:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
| BC Coilover settings you guys guys ride on | g0lden | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 04-06-2014 06:56 PM |
