Drives: 2015 FR-S
Collapsed PCV outlet hose to catch can
I installed a catch can from the earlier this year and just noticed that the outlet hose that goes from the back of the block to the catch can has pretty much collapsed (see pictures). This sort of intakes that somehow there vacuum inside the block?! or the heat somehow got to it? The hose from my catch can to the breather port of my Edlebrock SC is fine.
I bought the braided reinforced vacuum hoses at the same time and just cut it into 2 pieces. DID I BUY THE WRONG KIND?! I checked the catch can and there a little bit of oil as expected. When I installed the catch can I removed the bronze filter and replaced with steel scrubbing pad to allow better flow. I don't feel any issues or CEL but something is definitely wrong if the PVC hose collapsed. Previously without the catch can the hose provided by edlebrock worked perfectly. Let me know if there a specific vacuum hose I need that for this application many thanks |
Weight Weenie
Drives: 15 FR-S
I could be wrong but the looks like GP air hose to me. I can make out W P which stands for working pressure.
https://www.gates.com/us/en/fluid-po...l-purpose.html |
#3 | |
Drives: 2015 FR-S
Weight Weenie
Drives: 15 FR-S
Drives: 2015 FR-S
I would get silicone vacuum tubing.
Weight Weenie
Drives: 15 FR-S
I would imagine the GP hose would collapse under vacuum.
I haven't looked specifically for PCV hose/Vacuum hose. |
| Dual Radium catch can petcock hose routing | 86TOYO2k17 | Engine, Exhaust, Transmission | 1 | 01-01-2019 02:50 PM |
| [FS] Mishimoto Oil Catch Can Silicone Hose | Laz84 | Engine, Exhaust, Bolt-Ons | 1 | 12-20-2018 11:21 AM |
| FS: OFT/K&N Filter/Perrin Intake Hose/Nameless Cam Plate/Mishimoto Catch Can | The Tengu | Engine, Exhaust, Bolt-Ons | 19 | 03-01-2016 11:47 PM |
| Fuel pump outlet hose coming lose | phastafrican | Issues | Warranty | Recalls / TSB | 7 | 11-04-2014 05:38 PM |
| where to plug the oil catch can hose... :S | dompower | Engine, Exhaust, Transmission | 29 | 11-14-2012 12:30 PM |
