Drives: 2018 BRZ
Rate my brake dust boots
After about 400 miles on track, my front dust boots are starting to look bad. Rears look fine. How urgent is replacing them? Any options that will handle heat better? Or do I have to go BBK/cooling ducts/etc.?
Stock non-PP calipers, G-Loc R10 pads, not using shims/backing plate from the street pads (i.e. just the R10 pads directly). Left and right sides look about the same. Stock drivetrain. Front R10 pads are about half-way worn (~5 mm left). Car is daily driven all year with some snow and salt in winter. |
Drives: Toyota GT86
The AP racing bbk don't run dust boots so maybe they are not that important ha.
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
Drives: 2018 BRZ
Yeah, I read that many BBKs don't use dust boots and are not recommended for street use, particularly in winter with salt present on the roads. I'm sure plenty of folks run them on the street, though, so I don't know how important it truly is...
So even though those outer rubber boots are cracking, there are o-rings underneath that also provide a seal.
I’d say you’re fine for another track day, but for the price of replacement calipers I’d say just replace them for the peace of mind. https://www.ebay.com/itm/12421678108...mis&media=COPY |
Drives: '22 BRZ
Those look fine. Run them until they fall apart.
If you're not driving in salt, they'll last a long time if you clean the pistons off before compressing them.
Those are fine. When you have a chance physically feel them for hardness/brittleness.
What you don't want is a hardened seal getting caught. You can slow the degradation down using pads that fundamentally run cooler. |
Drives: 2018 BRZ
#8 | ||
Try the CSG C21/C11 pairing. Ask for temperature paint on the pads when you order to verify for yourself. From another post: Quote:
Wheels for Brains
Seem fine. I like to rebuild after every 15-20 events. It's easy enough to do and Subaru/Toyota have kits with all the seals+goop you need; recommend buying another set of base calipers so you don't have any downtime between rebuilds
I would say, if they ever develop a hole, just cut the boot off until you have time to rebuild the calipers. A hole causes the boot to trap more debris than it keeps away |
#10 |
Drives: 2018 BRZ
#11 |
Wheels for Brains
| do the “Performance Pack” Brembos have dust boots? | pkennethv | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-18-2021 04:40 PM |
| Steering Rack Dust Boots Melted. Replacement? | mistople | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 08-20-2019 12:34 PM |
| Calipers without dust boots | toast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 01-15-2016 01:27 PM |
| OEM Springs and Dust boots - Free Shipping | stefmiesterb | Brakes, Suspension, Chassis | 4 | 03-31-2015 07:03 PM |
| Shifter dust boots - $15.00 Shipped | SilentMike | Transmission and Driveline | 4 | 05-18-2014 02:43 PM |
