Northern California NorCal
Old 08-15-2023, 04:07 PM   #1
gepeyo
Opal86
gepeyo's Avatar
Drives: 2013 10 Series #Opal86
Weird Smog Check Failure
Hey Everyone, its been a while since I've posted in the forum.
I gotten notice that I had to take my car into a shop to have it Smog checked as a Star station, so I took in my car today to have it checked. My car was running perfectly fine and there was no check engine lights or anything prior to driving my car into the shop.
When I arrived at the shop, the guy took my car in and after 10 minutes he told me that my car's OBDII reader was not getting communication with their system whatsoever. After 3 tries though, he was able to get it to connect into their database but the Smog apparently failed due to an OBDII error with low communication. (Code U0155). After they returned my car to me, my car suddenly had a check engine light and it went into limp mode, which made me panic at first but I assume the smog checker caused this when it accessed my OBDII. Looking at the paper he gave me on return everything else passed besides the OBDII.
I was wondering if anyone experienced this when they had their car smogged?
The extra details:
Car had a UEL tuned with a open flash tablet in the past, but since then has been removed/untuned. It also passed smog 2 years ago after having the UEL and OFT taken off.
About 4 years back, my car has a CEL due to a solenoid valve breaking, its since then been fixed by a shop and hasnt been a problem since.
gepeyo is offline   Reply With Quote
Old 08-15-2023, 04:31 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What's the new code it's throwing? Were you able to pull it?
Originally Posted by humfrz
I'm old and lazy
Old 08-16-2023, 03:06 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
The extra details:
Same thing happened to me. Should be a simple fix with the right smog guy. Ill post my ordeal/fix in the morning for you
Old 08-16-2023, 01:00 PM   #4
finch1750
finch1750's Avatar
@gepeyo So I had the same thing happen with my car not reading on the machine, but when the tech went to try and push the connection better my dash through every light it could. Turning the car off and on cleared everything except the CEL. While not in limp mode, it did drive like total shit for a while while relearning.
I took the car to Neal's new shop and luckily he was there and helped get me squared away pretty easily.
The OBD on the early years get bad connections and don't read. He loaned me an obd extension and sent me to his smog guy around the corner and it passed no problem.
So try an extension and find a smog shop that will allow it. If that doesn't work the OBD port itself may need to be replaced.
Old 08-16-2023, 06:34 PM   #5
strat61caster
strat61caster's Avatar
+1 real fix is fixing/swapping the obd2 port so the pins engage properly. If you’re really skilled you can repin the original connector, I’m a monkey so I immediately broke it. Easiest I found is splicing in a pigtail I got from iwireusa.
ineedyourdiddly
Old 08-16-2023, 08:15 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
That's it. OP, you know how a wall socket wears out so we bend the prongs on the vacuum cleaner plug to make it work? Same thing, only now the plug has sixteen prongs/pins.
Old 08-16-2023, 11:51 PM   #7
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
This is an excellent analogy.
villainous_frx is offline   Reply With Quote
Old 08-17-2023, 05:54 PM   #8
jflogerzi
jflogerzi's Avatar
I have seen this when the port disconnects during my track days. I just used zip ties to make my reader very secure and its mostly not an issues now.
2013 Series 10 FRS #553
Old 09-12-2023, 11:54 AM   #9
finch1750
finch1750's Avatar
@gepeyo did you ever get this squared away?
California Smog Check Phantobe Southern California 144 06-20-2025 04:16 PM
Smog Check Exempt Counties Stigmaru Southern California 3 04-01-2023 06:18 PM
Understanding used car smog check timeline re-animator Southern California 7 07-12-2019 05:44 PM
CA Smog Check?? JG Southern California 22 06-08-2015 11:05 AM
Smog check and visual inspection help Corradooo Northern California 24 05-19-2014 11:57 PM
