| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives:
Oil change with 5W30. Did I overfill too much?
This is after running it hot and letting it sit for a few minutes. Did it again and let it sit for the whole 5 minutes as the manual says and it was a bit lower. Looks like low to full is about 1.1 qt.
Yes it’s the lower side you are looking at. ![]() [IMG]https://uploads.tapatalk-cdn.com/20230807/cb97e3417a382af0cf32***a2bf8e338.jpg[/IMG] Sent from my iPhone using Tapatalk |
not playing cards
It's fine. You overfilled it just enough.
Drives: '23 BRZ
Ha, yeah agree w/ @Ultramaroon. In fact this is just about the same amount Subie dealer over-filled mine, so when I went to overfill it by ~half a quart before track days and checked, it was already there!
Drives: 2013 FR-S Series 10
Is aerating the oil not a concern with boxer engines? That seems like quite a bit extra, probably a quart.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
not playing cards
There's plenty of extra room before that happens.
It is known.
Drives: BRZ 2023
Drives: GR86 (Sold) -> C6 GS Edelbrock SCed
The FA24 is a major oil burner, so your current oil level is ample. Be sure to check your oil frequently, they burn through oil like a 400,000 mile junker with bad rings
Drives: '23 BRZ
Mine has used about zero oil over the past 4500 miles and 4 track days. Same as my old FA20. Honestly I've *never* owned/tracked a car that didn't need at least half a quart between 5000-mile interval changes under similar usage, but my FA engines just don't use/burn much at all.
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The dipstick gets bent around and enters at quite a low angle.
It you flip it over to the other side, it will show closer to the full mark.
"I gotta rock." -- Charley Brown |
#10 |
Drives:
![]() From low to full is 1.1 QT. I’m not 100% sure it burns. It might a bit. But nothing crazy. Sent from my iPhone using Tapatalk |
#11 | |
not playing cards
edit: Ok, one did have issues with his 13 but his 14 is fine.
#12 | |
Proud of BOXER
Drives: Subaru Boxer
My 13 burned/consumed a lot (half quart every 3-4 weeks - low actual miles driven) but my 14 doesn't consume any.
#13 | |
Drives: GR86
I don't know for sure how much is too much (someone else probably does) but it's actually fairly routine to deliberately over-fill for track days by half a quart or more. |
#14 |
Drives: 2020 BRZ/86, 2020 BMW 330i
Curious to see the oil pressures in right turns on track with 1 quart overfill.
| Oil Overfill? | OldBiker | BRZ Second-Gen (2022+) — General Topics | 6 | 05-17-2023 12:01 PM |
| Oil Change Kit: Redline 5W30 + KN Oil Filter | skylinekin | Engine, Exhaust, Bolt-Ons | 0 | 12-27-2017 04:19 PM |
| Oil 5w30 | cooldandani | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 05-27-2015 09:50 AM |
| UOA 5w30 | Rocket.BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 49 | 07-07-2014 11:29 PM |
| [Updated] Oil Engine Overfill - 7.5QTs Courtesy of a Dealership | R.S-HawK | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 11-10-2013 11:16 PM |
