Old 08-07-2023, 07:24 PM   #1
Tomyyyu
Drives:
Oil change with 5W30. Did I overfill too much?
This is after running it hot and letting it sit for a few minutes. Did it again and let it sit for the whole 5 minutes as the manual says and it was a bit lower. Looks like low to full is about 1.1 qt.
Yes it’s the lower side you are looking at.
[IMG]https://uploads.tapatalk-cdn.com/20230807/cb97e3417a382af0cf32***a2bf8e338.jpg[/IMG]
Tomyyyu is offline   Reply With Quote
Old 08-07-2023, 08:01 PM   #2
It's fine. You overfilled it just enough.
Lantanafrs2 (08-07-2023), Teseo (08-07-2023), Tomyyyu (08-07-2023)
Old 08-07-2023, 08:46 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ha, yeah agree w/ @Ultramaroon. In fact this is just about the same amount Subie dealer over-filled mine, so when I went to overfill it by ~half a quart before track days and checked, it was already there!
The Following 2 Users Say Thank You to ZDan For This Useful Post:
Old 08-07-2023, 08:55 PM   #4
Decep
Drives: 2013 FR-S Series 10
Is aerating the oil not a concern with boxer engines? That seems like quite a bit extra, probably a quart.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 08-07-2023, 10:50 PM   #5
There's plenty of extra room before that happens.
It is known.
Spektyr (08-08-2023)
Old 08-08-2023, 01:51 AM   #6
ruturaj001
Drives: BRZ 2023
It's about 0.5 quart
ruturaj001 is offline   Reply With Quote
Old 08-08-2023, 05:05 AM   #7
Unplugem
Drives: GR86 (Sold) -> C6 GS Edelbrock SCed
The FA24 is a major oil burner, so your current oil level is ample. Be sure to check your oil frequently, they burn through oil like a 400,000 mile junker with bad rings .
Unplugem is offline   Reply With Quote
Old 08-08-2023, 09:52 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
Mine has used about zero oil over the past 4500 miles and 4 track days. Same as my old FA20. Honestly I've *never* owned/tracked a car that didn't need at least half a quart between 5000-mile interval changes under similar usage, but my FA engines just don't use/burn much at all.
DocWalt (08-08-2023), Spektyr (08-08-2023)
Old 08-08-2023, 11:11 AM   #9
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The dipstick gets bent around and enters at quite a low angle.
It you flip it over to the other side, it will show closer to the full mark.
Old 08-08-2023, 11:58 AM   #10
Tomyyyu
Drives:
From low to full is 1.1 QT. I’m not 100% sure it burns. It might a bit. But nothing crazy.
Old 08-08-2023, 12:12 PM   #11
Maybe yours did. Mine is still tight as a drum after 10 years, 60 Kmi. I've known plenty of owners. Not one has ever had issues with burning oil.
edit: Ok, one did have issues with his 13 but his 14 is fine.
Old 08-08-2023, 12:15 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
My 13 burned/consumed a lot (half quart every 3-4 weeks - low actual miles driven) but my 14 doesn't consume any.
Originally Posted by humfrz
I'm old and lazy
ZDan (08-08-2023)
Old 08-08-2023, 01:24 PM   #13
Spektyr
Drives: GR86
It is known.
To expand on that - the design of the boxer in general (and these in particular) allows far more excess oil before aeration becomes a problem. Where a typical I4, V6, etc. would foam up the oil with say half a quart excess oil these engines just don't care.
I don't know for sure how much is too much (someone else probably does) but it's actually fairly routine to deliberately over-fill for track days by half a quart or more.
Spektyr is offline   Reply With Quote
The Following User Says Thank You to Spektyr For This Useful Post:
Ultramaroon (08-08-2023)
Old 08-08-2023, 02:50 PM   #14
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
Curious to see the oil pressures in right turns on track with 1 quart overfill.
Arthur-A is offline   Reply With Quote
Oil Overfill? OldBiker BRZ Second-Gen (2022+) — General Topics 6 05-17-2023 12:01 PM
Oil Change Kit: Redline 5W30 + KN Oil Filter skylinekin Engine, Exhaust, Bolt-Ons 0 12-27-2017 04:19 PM
Oil 5w30 cooldandani Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 05-27-2015 09:50 AM
UOA 5w30 Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 07-07-2014 11:29 PM
[Updated] Oil Engine Overfill - 7.5QTs Courtesy of a Dealership R.S-HawK Scion FR-S / Toyota 86 GT86 General Forum 56 11-10-2013 11:16 PM
