Old 08-01-2023, 11:53 PM   #1
Stephen02
Stephen02's Avatar
Drives: 2013 Manual Trans FR-S
Any ideas on what's leaking?
It kind of looks like the oil pan gasket is leaking but I understand that that's rare for out cars. The oil pan is always coated with oil and theres always oil dripping from the drain plug. That may just be beause if it's the lowest point. I've replaced the drain plug with a Greddy one so it seems unlikely that a deformed plug was the cause.
Stephen02 is offline   Reply With Quote
Old 08-02-2023, 08:52 AM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Are you losing coolant? Those pictures look like there's a coolant leak from that heater hose.
The Following 4 Users Say Thank You to blsfrs For This Useful Post:
alphasaur (08-05-2023), NoHaveMSG (08-02-2023), Stephen02 (08-02-2023), Teseo (08-06-2023)
Old 08-02-2023, 11:10 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I agree.
The oil on the front crossmember is probably coming from a timing cover leak. Super common.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
blsfrs (08-02-2023), Stephen02 (08-02-2023)
Old 08-02-2023, 01:05 PM   #4
Stephen02
Stephen02's Avatar
I am losing coolant very slowly. I changed the coolant a couple years ago so I'll probably just replace that hose when it's time to change it again.
Old 08-03-2023, 08:52 AM   #5
blsfrs
blsfrs's Avatar
Given that the fluid from the leak looks rusty, it might be a pinhole leak in the metal pipe.
Also, if the timing cover is leaking as @NoHaveMSG suggested, I've heard of folks getting a temporary fix by cleaning the area and applying a layer of RTV over the seam.
The Following User Says Thank You to blsfrs For This Useful Post:
NoHaveMSG (08-03-2023)
Old 08-03-2023, 12:27 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
Why would the splash pattern face forward? I think this was a one-time incident.
Old 08-03-2023, 02:57 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I did not notice that
The Following User Says Thank You to NoHaveMSG For This Useful Post:
Ultramaroon (08-03-2023)
Old 08-03-2023, 03:24 PM   #8
blsfrs
blsfrs's Avatar
Are you suggesting that he ran over a cow pie?
Old 08-03-2023, 03:38 PM   #9
Ultramaroon
not playing cards
I'm suggesting that he may have backed over one.
blsfrs (08-04-2023)
Old 08-04-2023, 11:18 PM   #10
Grady
Grady's Avatar
I do not see a leak anywhere. The key to finding leaks is to clean everything and then monitor.
The Following 2 Users Say Thank You to Grady For This Useful Post:
soundman98 (08-05-2023), Teseo (08-06-2023)
Help- Oil leaking through AOS neroman98 Engine, Exhaust, Transmission 21 03-31-2020 09:02 PM
Oil Leaking?? tonytduc Issues | Warranty | Recalls / TSB 371 11-13-2016 07:14 PM
Car leaking davebrus Issues | Warranty | Recalls / TSB 4 03-21-2014 11:23 AM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
