Old 07-20-2023, 10:48 AM   #1
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
2nd gen wheel fitment suggestions
I dont plan on a big brake kit, maybe coilovers down the road but not slammed, I dont want to add spacers, I dont want to modify body panels or deal with rubbing or scrubbing. I want to buy 245/40/17 tires and looking for either flush and or a scooch of poke is ok. If I do lower it it will NOT have the tire up in the wheel well by any means. So I want to be able to lower or keep stock without issues.
What wheel width and offset is best to accomplish this?
I understand if I do lower it It will tuck in the fender a little bit.
Im looking at rpf1 +45 9" just wanted to confirm of fitment gurus if this is best. Seem to get conflicting info on fitment.com with flush/poke
thank you
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
Old 07-20-2023, 05:53 PM   #2
ruturaj001
Drives: BRZ 2023
It's tricky, +45 9" would fit but with you probably might not be able to add more camber (just camber or lower it).
ruturaj001 is offline   Reply With Quote
Old 07-20-2023, 06:47 PM   #3
Pat
Pat's Avatar
Drives: 2023 BRZ
Fitment Guide
Old 07-20-2023, 08:00 PM   #4
ProGodLegend
ProGodLegend's Avatar
Drives: 22 Subaru BRZ WRB
I'm running a 17x9 et42 with 245/40/17 and fits perfect with coilovers. It was close to rubbing on the inside on stock suspension.
Sent from my Pixel 6 using Tapatalk
ProGodLegend is offline   Reply With Quote
Old 07-20-2023, 08:02 PM   #5
ProGodLegend
Here's a pic
Old 07-23-2023, 08:39 AM   #6
vindiesel
vindiesel's Avatar
Upon farther research of someone comes across this thread
On stock suspension 2nd gen
With a “flush fitment”
17 or 18 inch wheel x 8 inch wide.. run + 35 offset
17 or 18 inch wheel x 8.5 inch wide… run +40 offset
Some wheels have goofy offsets like 38 or 42… so depends if you want slight poke or nearly flush.
If you run a x9 inch wide wheel on stock suspension you will have rubbing issues and requires aftermarket suspension adjustments to work
If any of this needs corrected let me know.
Any 3 piece wheel shop repair suggestions or wheel repair shops? kyle116 Southern California 7 07-24-2021 12:55 AM
Looking for Retro Wheel Suggestions MaverickMonk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 04-10-2019 08:26 PM
lightweight wheel suggestions, ~17x7 wired Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 09-21-2018 08:29 PM
Wheel repair suggestions? mrha Southern California 10 07-16-2013 03:57 PM
Wheel suggestions... wootwoot Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-05-2012 01:00 PM
