Southern California SoCal
Old 06-17-2021, 05:05 PM   #1
kyle116
Drives: 2015 Scion FR-S
Any 3 piece wheel shop repair suggestions or wheel repair shops?
Got some curbed outer lip SSR SP1s. Any suggestions on shops or how to fix? So far I've been told that I would have to get them weld filled and slightly reshaped. Its really only the outer lip thats been curbed
I also been quoted all over the place for fixing 2 wheels from:
3piece.us - $1200
Southern California Wheel Repair - $180
kyle116 is offline   Reply With Quote
Old 06-17-2021, 05:10 PM   #2
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
3piece.us - $1200
3pc.us is quoting for complete replacement barrels.
A wheel shop will repair the existing barrels by sanding/smoothing/welding new material
EndlessAzure is offline   Reply With Quote
Old 06-17-2021, 05:16 PM   #3
kyle116
Ah ok I see, this would fall in line more with just repair right? or do you have a suggestion to do one or the other?
Old 06-17-2021, 05:51 PM   #4
EndlessAzure
Wheels for Brains
Depends on your budget and the level of damage to the wheels.
If the damage is cosmetic only, a good wheel shop can fix it up without needing to worry about impact to wheel strength
If the wheels are damaged badly (bent or cracked) or needs welding, it depends on your risk tolerance and trust of wheel shop to make the repair. Even after repair, you should always regularly check the wheel to see if cracks form. If you don't trust the repair, replace the barrel
For the damage on the wheel you showed, it seems cosmetic only
The Following User Says Thank You to EndlessAzure For This Useful Post:
bcj (06-18-2021)
Old 06-17-2021, 06:23 PM   #5
kyle116
Ah thanks ok that makes sense and what I was thinking too. That was really helpful, thank you for providing clarity and info on all this
The Following User Says Thank You to kyle116 For This Useful Post:
bcj (06-18-2021)
Old 06-18-2021, 04:09 AM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Go to vrwheels
Decimus is offline   Reply With Quote
Old 06-27-2021, 12:13 PM   #7
Thaeyo
Thaeyo's Avatar
+1 for VRWheels as well in City of Industry
Thaeyo is offline   Reply With Quote
Old 07-24-2021, 12:55 AM   #8
Wraith
Drives: 2013
Rays Custom out here in Riverside does amazing jobs !!!
Wraith is offline   Reply With Quote
3 piece repair, ssr, three piece wheel repair, wheel repair
wheel repair shop in phx ? RNDerpy Arizona 1 01-21-2022 06:20 PM
Wheel Repair FTKID Southern California 2 05-12-2016 11:46 AM
wheel repair/powder coat shop in Portland? BRZPDX Northwest 10 08-20-2014 10:20 PM
Wheel Repair near SJ? brz408 Northern California 8 04-14-2014 09:33 PM
Wheel repair suggestions? mrha Southern California 10 07-16-2013 03:57 PM
