Old 07-18-2023, 06:39 PM   #1
SOCON
SOCON's Avatar
Drives: 2017 WR Blue PP
Manual tranny will not go into gear
I should consider myself lucky, had the car 5 years and FI a couple,mostly trouble free, now over 100k miles a couple issues have arisen. Foremost is that the car will not go into any gear when fully stopped at a light etc. Shifts fine with engine off. Changed oil, refilled with genuine Subi GL3 dope. Problem persists. After several searches it is starting to sound like shifter fork is wetting the bed. Before dumping a couple hundred bucks into a Verus fork, ball, and bearing, is there anything I may be overlooking?
Thanks
SOCON is offline   Reply With Quote
Old 07-18-2023, 06:50 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
stock clutch?
Old 07-19-2023, 06:11 AM   #3
SOCON
SOCON's Avatar
ACT SB8-HDSS
Old 07-19-2023, 08:36 AM   #4
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
No question at all. Go with the Verus fork and ball.
The Following User Says Thank You to blsfrs For This Useful Post:
SOCON (07-19-2023)
Old 07-19-2023, 06:53 PM   #5
Grady
Grady's Avatar
Put in gear, push clutch in then start. Tell us how that feels. Verus does not make a shifter fork. Let’s hope it is the clutch fork that they do make.
Old 07-19-2023, 08:45 PM   #6
SOCON
SOCON's Avatar
Grady, it was a long hot day yesterday. Clutch fork was the intended target.
Starts fine in gear with clutch depressed. Especially with the AC on, it will randomly stall while sitting at a red light when in first gear. I just flushed clutch cylinders with DOT 3 and checked pedal free play. Removed the dust cover on left side of tranny and tried to get a mirror and flashlight worked around to inspect the ball perch for cracking but could not get a good angle on my bi-focals
The Following User Says Thank You to SOCON For This Useful Post:
humfrz (07-19-2023)
Old 07-19-2023, 09:12 PM   #7
humfrz
Could it be that either the master or slave clutch cylinder is bad?
SOCON (07-20-2023)
Old 07-19-2023, 09:19 PM   #8
SOCON
SOCON's Avatar
Pedal does not feel mushy. No sign of external leakage. Does not make any difference if I pump the pedal
humfrz (07-20-2023)
Old 07-19-2023, 10:17 PM   #9
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Where does the pedal grab on the clutch? Close to floor? Pedal been adjusted?
Verus fork is a smart upgrade, know one person locally that solved their shift issues with an upgraded fork.
The Following User Says Thank You to RToyo86 For This Useful Post:
SOCON (07-20-2023)
Old 07-20-2023, 12:17 AM   #10
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Going to go on experience and say it's the ACT clutch system itself.
Clutch drag is not an uncommon issue among ACT clutches. I had an ACT that did the same, especially after driving a few blocks and warming the system up. My friend had similar issues on his ACT system, and other accounts have been recorded on this forum as well.
I ended up putting the OEM clutch system back into the car, and it drove perfectly fine again.
Try racing the engine with the clutch pedal depressed next time you're stuck at a light. It can help slip the friction disk away from the flywheel/plate. It's not a fix, but at least it can help you get out of a pinch
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
SOCON (07-20-2023), soundman98 (07-20-2023)
Old 07-20-2023, 08:35 AM   #11
Grady
Grady's Avatar
Now that you mention heat, does this only happen when it is hot? I had something similar just not as bad as you have described. It would show it self in traffic and especially coming off the track in the summer. I switched to 75W140 never have had an issue since.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Packofcrows (07-20-2023), SOCON (07-20-2023)
Old 07-20-2023, 04:51 PM   #12
SOCON
SOCON's Avatar
1-2 inches from the top
Old 07-20-2023, 04:56 PM   #13
SOCON
SOCON's Avatar
It does get worse after driving awhile. Heat does play a part for sure. I just replaced the 1.5 year old Motul with genuine Subi 85-140 to no avail.
Old 07-20-2023, 05:06 PM   #14
SOCON
SOCON's Avatar
Sounds to me the most likely case. Installed April of last year and has done ok until recently. The Verus fork would surely be an improvement over stock, but if bending fork were the root cause, pedal engagement would be right on the floor. IMHO
manual tranny bjun BRZ First-Gen (2012+) — General Topics 19 01-29-2013 05:57 PM
How's the drive using traffic? Manual tranny only gunmetal5 Scion FR-S / Toyota 86 GT86 General Forum 32 10-26-2012 03:21 PM
new manual driver: does this destroy my tranny? Saibot Engine, Exhaust, Transmission 45 07-13-2012 07:20 PM
Manual tranny takes another step into oblivion madfast Other Vehicles & General Automotive Discussions 76 03-06-2012 09:40 PM
