Old 07-13-2023, 11:17 PM   #1
EvilPenguin04
Drives: 2015 BRZ 2004 SVT Cobra
B14A1 causing other issues
I know there are a bunch of threads on this code but I haven't found a thread covering the problems we are having when this code gets thrown.
Car is a 15 BRZ Automatic, Sprintex 210, header, 45% E85. Tonight, we went to the track just to have fun but it turned into a frustrating night. It runs flawlessly normally with no code thrown, but when we figured out the code tripped tonight the idle RPM dropped to 500 or so, it wouldn't stall above 2k RPM wouldn't do a burnout and just driving home the car bucked and was just generally unhappy.
Anyone had similar issues and solutions?
EvilPenguin04 is offline   Reply With Quote
Old 07-14-2023, 02:15 AM   #2
tomm.brz
Drives: brz 2017 hksv2
No
that code is unrelated to the problems you are having
i suggest u log when you get that
Old 07-14-2023, 05:48 AM   #3
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Originally Posted by EvilPenguin04 View Post
Tonight
That's why you're getting that code. I get those codes when cars are inside the shop. The sunload sensor output gets so low at night/inside that it stores a harmless error code about it in the HVAC control module.
Your car freaked out and it just happened to be in memory when you scanned the whole network, but it's not the issue you're looking for.
Old 07-14-2023, 05:24 PM   #4
EvilPenguin04
Originally Posted by tomm.brz View Post
No
I'll get a log next time I can. Car runs great otherwise.
TechStream Error Code B14A1 developer Issues | Warranty | Recalls / TSB 13 10-08-2018 07:22 AM
High Negative LTFT on N/A BRZ causing idling issues paintdude258 Software Tuning 57 03-26-2017 08:14 AM
CEL Code B14A1 with auto AC on tripjammer Engine, Exhaust, Transmission 3 10-21-2016 05:04 PM
Error code B14A1... wth is it? SirBrass Software Tuning 4 04-24-2014 05:37 PM
What is causing this sound? Gixxer86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-29-2013 01:28 PM
