Old 07-07-2023, 03:27 PM   #1
Conti93
Conti93's Avatar
Drives: '02 Speedster n°586 - '23 GR86
2015 FR-S BIU/Integ Unit Assy replacement
Hi all!
I've got an FR-S of a friend of mine without keyless (so blade key) which was flooded and I'm replacing the BCM/BIU aka Integration Unit Assembly.
Since it has the normal key, AFAIK, the immo info is stored in the Integ Unit Assy AND the cluster. The latter was not submerged, so it's fine; for the Integ Unit Assy unfortunately there's a pin completely missing in the MCU, so I've found an identical one (there are three version for each region.. I erred on the safe side) P/N 88281CA220.
AFAIK the immo info is stored inside this module in the 93C86, dumb question: can I simply swap the EEPROM content between the two modules?
I've attached the two files if anyone wants to take a peek.
Thanks.
Conti93 is offline   Reply With Quote
Old 03-13-2025, 07:58 AM   #2
Conti93
Conti93's Avatar
Yes. simply swap EEPROM from the same P/N BIU and then do an ECU Communication ID reregistration as per TSB posted here.
Looking for BeSpoke head unit replacement Glok24 Electronics | Audio | NAV | Infotainment 9 10-18-2016 03:25 PM
2016 BRZ Head unit replacement shagoth Electronics | Audio | NAV | Infotainment 28 03-24-2016 04:40 PM
replacement headlight unit not focused Stratoside Issues | Warranty | Recalls / TSB 6 01-15-2016 03:24 PM
Exedy OEM Replacement Clutch Subaru BRZ 2013-2015 / Scion FR-S 2013-2015 **New Site** RallySport Direct Transmission and Driveline 59 09-01-2015 12:18 PM
Recommended Non Navigation Replacement Head Unit? brillo Electronics | Audio | NAV | Infotainment 3 12-18-2012 02:53 PM
