Old 07-06-2023, 03:29 AM   #1
ruturaj001
Drives: BRZ 2023
Redline MT gear oil options
75W90 has been extensively used on 1st gen, while 2nd gen, with minor difference in transmission, as per the manual, requires MT-LV (75W) oil. I looked at all the options redline offers and decided to make a list with relevant numbers
Vis @ 100°C, CSt Vis @ 40°C, CSt
MT-LV 70W/75W 6.5 29.8
MTL 75W80 10.4 50.8
MT-85 75W85 12 62
MT-90 75W90 15.5 82
I am on stock fluid, I assume it's 75W only. I am planning to try 75W80 next time then keep going to next one at every change till I find it's not to my liking or I am on MT-90. 75W80 seems like significant improvement over 75W, just looking at numbers.
ruturaj001 is offline   Reply With Quote
Old 07-11-2023, 11:37 PM   #2
ruturaj001
Drives: BRZ 2023
Update: Ended up ordering Redline MTL from CSG. I am planning to use it for a year and then get UOA. The try higher viscosity based on that. For diff I went with Motul 300 LS.
The Following User Says Thank You to ruturaj001 For This Useful Post:
CSG Mike (07-12-2023)
Old 07-12-2023, 11:46 PM   #3
ruturaj001
Drives: BRZ 2023
@CSG Mike, I went by your recommendation in old comments for diff fluid. MTL being listed on CSG convinced me enough to try it but would like to hear what are your thoughts on all MTF fluid viscosities and who would those be good for?
Edit 1: Also MOTUL GEAR POWER 75W-80 seems to be new. Are you guys planning to stock it as well?
Edit 2: Seems like it's not for US yet https://new.motul.com/en-FR/products...R+POWER+75W-80
gear knob -options Legend@wheels Cosmetic Modification (Interior/Exterior/Lighting) 11 12-10-2018 03:32 AM
Motul gear 300 or Redline MT90? BRZ NA Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 70 11-30-2016 04:02 PM
3rd-4th gear grind...but only near redline hushypushy Engine, Exhaust, Transmission 89 06-03-2016 10:39 PM
Motor Oil, Gear Oil, Oil Filters, Company 23, Motul, Redline, Eneos, SubaruOEM @OAKOS OAKOS Automotive Mechanical Maintenance and Tools 34 02-26-2016 11:26 AM
Transmission fluid blending Redline MTL and Motul Gear 300 okay? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-01-2013 09:03 PM
