Old 07-03-2023, 08:54 AM   #1
CastrolTom's86
CastrolTom's86's Avatar
Drives: It goes br-br-br-br-BRAAAAApppppp
Did I put the wrong oil on my TRD air filter?
I have a TRD airbox and a couple of days ago I cleaned out the filter using aFe Power's air filter restore kit with the gold oil. I selected this cleaning kit because I found a TRD high air filter cleaning kit which appeared to be a relabeled version of the aFe kit. After cleaning the filter and applying the oil, it seems that my miles per gallon have decreased. Did I over oil the filter? Or did I use the wrong filter? Or is it just me thinking the MPGs decreased?
CastrolTom's86 is offline   Reply With Quote
Old 07-03-2023, 11:17 AM   #2
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I cannot comment on AFE products. Have not used them.
I would suspect that the TRD filter is a K&N product.
Perhaps try K&N filter cleaning and oiling products.
Regarding over-oiling. This can be an issue. I’ve used oiled K&N filters since 1988 in all my vehicles and have never had a MAP sensor fouled, as many users have. If fouled it is easily cleaned with Aerosol MAP Sensor cleaner. Do not physically touch the sensor internals. Just blast with the cleaner and air dry.
My maintenance process is as follows;
Remove soiled K&N filter and if a DD temporarily re-installed the paper filter it replaced.
-Using K&N product and following the instructions clean the filter and back flush.
-Allow the filter to dry overnight perhaps outside in a sunny location. Do not use compressed air or a hot blow dryer.
-Next day apply the oil generously into the pleats as per the instructions. Lay out some paper towels and set the oiled filter on them over-night to drain excess oil.
-Next day re-install the K&N and store away the paper filter for the next cleaning process.
Good Luck and enjoy!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 07-04-2023, 10:44 AM   #3
CastrolTom's86
The TRD cleaning kit in the picture is a relabeled aFe kit, but there is another TRD cleaning kit with a spray bottle. The issue with this kit is that the oil bottle dispenses too much oil. The instructions say not to overapply and put an even coating across the filter but it's difficult to do so without a spray bottle.
I just started my car today and have a check engine light. I'm guessing it's the MAF sensor because OFT indicated there were no codes. I guess the next step is to clean out the MAF sensor?
Old 07-04-2023, 11:06 AM   #4
Muskoka800
Hmmmm. The TRD kit looks identical (re-labelled) to the K&N kit I have in stock.
If I recall, back in the day the kit did come with aerosol oil but has changed over the years.
Now that you have run the car any excess oil will have been pulled from the filter element.
Clean the MAP and you should be set.
Old 07-04-2023, 11:11 AM   #5
OND
OND's Avatar
Drives: 2023 BRZ
Yep, over oiled. I always used the KN kit with spray oil and never had an issue.
OND is offline   Reply With Quote
afe, cleaning kit, trd air filter
FS (MD): Grimmspeed Intake, Perrin Inlet/CAI Filter, Green Air Filter s203.22b Engine, Exhaust, Bolt-Ons 1 03-08-2021 12:25 PM
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 02:46 AM
Renick Subaru installed the wrong filter! blkwrxwag Southern California 13 06-05-2013 01:44 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
