Old 07-02-2023, 12:16 PM   #1
Maafeu
Drives: 2022 GR86
BIN File request from 2017+ 86 Speedo
Hey Guys,
I was doing a little upgrading on my cluster and I seem to have corrupted the BIN file responsible for the mileage.
Does anyone have a virgin / working BIN file from a 2017+ cluster I can use? I'm not sure if this make a difference for proper operation, but my cluster came from Japan on an automatic car.
For testing purposes, any bin file from a 2017+ cluster would be most appreciated.
Thanks in advance.
Maafeu is offline   Reply With Quote
Old 07-05-2023, 09:57 PM   #2
RedReplicant
Drives: None
Originally Posted by Maafeu View Post
Hey Guys,
Thanks in advance.
Gerald posted one here http://www.geraldjustprojects.com/wp...d-667.BIN_.zip
He also posted the main larger flash chip that has the images for menus
http://www.geraldjustprojects.com/wp...GL128S_BRZ.zip
http://www.geraldjustprojects.com/wp...6_2019_TRD.zip
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Maafeu (08-16-2023)
Old 07-12-2023, 10:26 AM   #3
ajaxburger
ajaxburger's Avatar
Drives: 2017 BRZ Limited Perf. Pack
May be unrelated but do you have a link to a thread where I can find instructions on how to read the data on the cluster?
Have a 2017 and curious about modifying it.
zoom zoom... wait wrong company
ajaxburger is offline   Reply With Quote
Old 08-16-2023, 10:44 PM   #4
Maafeu
Drives: 2022 GR86
Originally Posted by RedReplicant View Post
Dude...Thanks a million. I will try it out and make sure it's all working but this is amazing. Much appreciated!!
Update: Sadly it's a bummed file. not read properly. Are there any other ones on there that you can find?
Thanks in advance.
Old 08-16-2023, 11:06 PM   #5
Maafeu
Drives: 2022 GR86
So first thing you'll need to do it get a chip reader, I suggest the EZP2019+. It comes with all the attachments you'll need to connect to the chip. Also comes with the software to read it. Once you connect to the chip and read there information, there's three locations within the first two lines that carry the mileage information. Those are read in Hex format and need to be updated to reflect your current mileage. Once that's updated, you'll have to write it back to your chip and you should be good to go.
I'm currently working on mine right now. i was able to play around with it on my 2013 cluster. but I'm going to try it on my 2017+ cluster.
Old 09-14-2023, 06:09 PM   #6
ajaxburger
ajaxburger's Avatar
Just saw your PM.. never got around to doing it but looking at the hardware you mentioned it's definitely going to be a down-the-road project for me I've been feeling particularly lazy when it comes to tinkering with my car given the weather right now.
Speedo Correction SCFD Electronics | Audio | NAV | Infotainment 2 04-28-2021 03:22 AM
2017 at model k00d definition file kdyg123456 Software Tuning 9 10-13-2018 10:24 PM
Ori file request -asap- halujeddo Software Tuning 1 12-10-2017 04:19 PM
2017 86/brz ecu def file available? Chr15 Software Tuning 6 11-24-2016 10:23 PM
OFT - Mode file not found. Cannot create a tuning file. focobrz Software Tuning 11 07-17-2015 09:22 PM
