Old 04-27-2021, 09:38 PM   #1
SCFD
Speedo Correction
I think our speedometer reads high from the factory but I went with some undersized tires so my speedo is probably off by quite a large margin. Is there a way to re-calibrate the speedo?
SCFD is offline   Reply With Quote
Old 04-27-2021, 10:59 PM   #2
OsageJJ
OsageJJ's Avatar
Drives: 2019 Toyota 86 TRD SE
I would recommend taking a look at the Yellow Box Speedo Recalibrator (www.yellr.com). The company that makes it is based out of Australia, and I used an earlier version of this device in a 2003 Toyota Tundra. With a GPS unit, I was able to verify that it worked flawlessly in that application. For our twins, I suspect that you'd probably need to splice into the "SPD" signal wire found in the wiring diagrams (pink with a green stripe, at least in my particular copy of that diagram).
OsageJJ is offline   Reply With Quote
Old 04-28-2021, 03:22 AM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
It's been several months since I've run the EcuTek Pro ECU software, but I believe there are some settings in there to correct for over or under sized tires.
That would mean you would need an EcuTek tune.....
.....But, there may be some settings in the Techstream (or Subarus equivalent) diagnostic software that the dealers use to perform those adjustments. I'm sure someone here who is more familiar with Techstream will chime in to verify.
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Correcting speedo error ZAZ AUSTRALIA 1 11-19-2018 04:29 AM
Upsizing to 18s, Speedo changes Tectoniic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 02-18-2016 10:12 AM
The speedo sucks ! Mikem53 Scion FR-S / Toyota 86 GT86 General Forum 69 05-21-2015 05:12 AM
Speedo issues Venator Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-14-2014 08:10 AM
Any way to mod the speedo MPH reading? Tromatic Cosmetic Modification (Interior/Exterior/Lighting) 7 06-24-2013 10:34 PM
