Old 06-24-2023, 02:01 AM   #1
SlwFRZ86
SlwFRZ86's Avatar
Drives: 17 brz limited
Suspension Questions
As the title says i have a couple of question I cant find. I am inept when it comes to searching in forums.
I am upgrading my suspension slowly.
1. I am getting SPL RLCA can i run it without getting the SPL adjustable toe arms? Anyone have documentation of installing the SPL RLCA.
2. Currently, I have 1 coilover higher than the rest can this make the car shake over 65 mph ? ( will be fixing soon in like a day or two )
SlwFRZ86 is offline   Reply With Quote
Old 06-24-2023, 02:56 AM   #2
strat61caster
strat61caster's Avatar
1. Yes, yes, https://www.splparts.com/content/SPL%20RLL%20FRS.pdf
2. If it's a only a little bit - no, if it's a ton maybe. More likely an unbalanced wheel or bad alignment.
ineedyourdiddly
Old 06-25-2023, 12:35 AM   #3
SlwFRZ86
SlwFRZ86's Avatar
Thanks for the reply. Yea im not sure. i got it professionally aligned and got paper work on how bad the previous alignment was and got the balanced check 3 times it was good. I did find that my rear is having a weird thing where the rear ride height changes on both sides ( 1 side is on the normal ride height and 1 side is higher and then it switches over sometimes ) im checking the whole rear tomorrow.
Upgrading my rear suspension questions mjh712 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 12-23-2021 11:47 AM
Suspension Questions (Not for FR-S) Toyarzee Other Vehicles & General Automotive Discussions 23 11-02-2015 10:30 PM
Suspension questions Ludacrits Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-07-2014 09:07 PM
Questions on Suspension Geometry Zach3794 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 07-02-2013 10:53 PM
Anyone Need Suspension Help??? | Post Your Questions | THMotorsports THMotorsports.com Brakes, Suspension, Chassis 24 02-01-2013 06:18 PM
