Old 06-19-2023, 10:29 PM   #1
geraldjust
Drives: MR2, Sliver BRZ
Highest recored oil PSI
Wondering from you track guys, whats the highest oil PSI you seen? for those running gauges.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 06-20-2023, 10:02 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
At operating temp, 0-20 oil. 58psi coming from the port off the top of the engine on my innovate gauge.
Old 06-20-2023, 10:30 AM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I'm not really tracking right now, but I'm getting my pressure right off of the pump. What kind of conditions are you wanting to see? Temp, rpm, start-up?
dragoontwo is offline   Reply With Quote
Old 06-20-2023, 10:55 AM   #4
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I run 10w40 as the builder recommends and on cold start in cold weather it can be north of 100psi measured from the top block port. Once it reaches operating temp it idles at 20psi.
Breadman is offline   Reply With Quote
Old 06-20-2023, 11:27 AM   #5
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
When you say: "right off of the pump"? Do you have some custom plumbing?
Old 06-20-2023, 12:22 PM   #6
dragoontwo
dragoontwo's Avatar
Drilled/tapped at the nipple on the front cover coming right off of the oil pump next to the crank pulley.
Old 06-20-2023, 12:52 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
With, or without a cooler? With 0-20 I still get what book says I should. 73-ish PSI at 180-ish degF.
115-ish PSI at high idle on cold start
Old 06-20-2023, 02:56 PM   #8
blsfrs
blsfrs's Avatar
Cool. Could you post a picture?
Which galley are you in? Are you measuring pressure before or after the filter?
Old 06-21-2023, 06:55 AM   #9
dragoontwo
dragoontwo's Avatar
Pre filter, right out of the pump. As of right now I did this about 3 months ago. I still DD and autocross once a month right now. Let me go find the thread that inspired me. I'll edit this post.
Here's the thread.
Here's an image that I haven't put out there yet, because I wasn't sure how the engine would respond.
Highest mileage 2nd gen vindiesel BRZ Second-Gen (2022+) — General Topics 10 07-07-2023 09:37 AM
Highest mileage 86 South Africa Issues | Warranty | Recalls / TSB 5 02-26-2016 09:13 AM
Who has the highest N/A 86/BRZ/FRS? Jeremy Engine, Exhaust, Transmission 45 02-17-2016 09:27 AM
Highest WHP edamons Engine, Exhaust, Transmission 21 09-17-2013 05:53 PM
highest mpg possible steve87j Scion FR-S / Toyota 86 GT86 General Forum 29 12-28-2012 08:06 PM
