Old 06-03-2023, 04:49 PM   #1
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Shelf life for open brake fluid
Once you crack the seal on brake fluid is it safe to use again after its been sitting for a few months ?
I am looking to bleed my brakes tomorrow and would like to finish off what's left of my castrol SRF plus open another new bottle that I would plan on using again next time I bleed the brakes
any issues with that plan ??
Thanks
autoracer86 is offline   Reply With Quote
Old 06-04-2023, 12:55 AM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Thanks
Probably fine. If you worried about it, pour it into your super clean jar, or measuring cup and look at it. If it looks like vegetable oil, cool. Looks like motor oil, no.
autoracer86 (06-04-2023), soundman98 (06-04-2023)
Old 06-04-2023, 02:34 AM   #3
steved
Drives: 2013 FRS
https://blog.amsoil.com/dot-3-and-do...he-difference/
Mentions dot3 can absorb 2% per year, the more moisture in the brake fluid the lower the boiling point will be. I won't use old bottles myself, especially if it's going on track.
steved is offline   Reply With Quote
Old 06-04-2023, 02:44 AM   #4
autoracer86
Drives: Toyota GT86
Hmm the old fluid is not even a year old but I guess some moisture might have got In. I do keep it inside my house rather than outside in a garage if that matters lol
Thanks for the link
Old 06-04-2023, 01:44 PM   #5
autoracer86
Drives: Toyota GT86
Okay I used some of the new bottle mixed with the rest of the old bottle. Job done and the brakes feel great. We will see how they hold up long term
Old 06-04-2023, 02:30 PM   #6
Jdmjunkie
Drives: Scion FR-S 10 Series
Plastic wrap over top of the opening and then putting the cap on top of that might be an effective moisture barrier.
Jdmjunkie is offline   Reply With Quote
Old 06-04-2023, 04:02 PM   #7
Teseo
Drives: frs
Put the un-used bottle in your drawer
Old 06-04-2023, 04:07 PM   #8
soundman98
ProCrastinationConsultant
soundman98's Avatar
next to your panties.
Clipdat (06-05-2023)
Old 06-04-2023, 04:52 PM   #9
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
instructions unclear, everything is in a bunch now.
villainous_frx is offline   Reply With Quote
The Following 3 Users Say Thank You to villainous_frx For This Useful Post:
Ohio Enthusiast (06-04-2023), soundman98 (06-04-2023), Ultramaroon (06-08-2023)
Old 06-08-2023, 07:18 PM   #10
Grady
Grady's Avatar
If the cap is tight it can only absorb what moisture is inside the bottle. 2 months 2 years does not make any difference. You will be fine. If you store it outside with the cap off I would not use it.
The Following 3 Users Say Thank You to Grady For This Useful Post:
autoracer86 (06-09-2023), Dzmitry (06-14-2023), humfrz (06-10-2023)
Old 06-08-2023, 08:10 PM   #11
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
I have a bottle of Stoptech SRF660 fluid that was opened ~4 years ago. Just tested it a few days ago with test strips. The strip barely showed any contamination at all. It probably is at least 98% good. Bottle was sealed with just the regular cap and stored in my garage.
Sevs753 is offline   Reply With Quote
The Following 5 Users Say Thank You to Sevs753 For This Useful Post:
autoracer86 (06-09-2023), Dzmitry (06-14-2023), jflBRZ (06-27-2023), Ohio Enthusiast (06-08-2023), soundman98 (06-08-2023)
Tyre storage and shelf life. Captain Snooze Tracking / Autocross / HPDE / Drifting 1 07-02-2019 08:36 AM
I want this in my life (brake duct) chaoskaze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 62 03-14-2018 11:47 PM
OEM Brake Pad Life Cal3000 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-03-2014 06:39 AM
Track day brake life? transition Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-03-2014 04:57 AM
Brake Fluid shelf life? VoiD Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-02-2013 06:17 PM
