Old 05-10-2023, 05:47 PM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Lowering springs for '22/'23, bump travel?
Would lowering springs for 1st gen fit 2nd-gen? Not finding a lot of 2nd-gen-specific options out there... Ideally want something like Swift Spec-R spring rates (4.4F/5.3R).
How are the factory '22/'23 for strut/shocks bump travel, i.e. how low can you go with the stock dampers?
Application: daily-driver and time-trials car. Tenths of a second *matter*. Also considering RCE SS-2 coilovers, but with them I'd have to add 80 lb. of ballast...
Old 05-11-2023, 09:02 AM   #2
nomtimesthree
Drives: GR86
Seems like there's something different with the spring seat, so ymmv. Probably better off getting springs designed around the 22+ cars.
See: https://tinyurl.com/mrr6w6he
Coilovers, sway bars and brakes are interchangeable if you have a GR86. 22+ BRZ has a different front knuckle which may cause issues with some BBKs and the rear sway mounts are different, but I think the bars will fit if you have the right hardware.
nomtimesthree is offline   Reply With Quote
Old 05-11-2023, 09:11 AM   #3
Racecomp Engineering
What they said.
Also total travel is the same 1st gen vs 2nd gen OEM dampers.
You could swap your complete Bilstein + Swift assembly over to 2nd gen if you want.
- Andrew
Old 05-11-2023, 09:12 AM   #4
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The are mounted different, but the bar occupies the same physical space. All bars that fit previous gens will fit unless they need spacers.
dragoontwo is offline   Reply With Quote
Old 05-11-2023, 09:23 AM   #5
nomtimesthree
Drives: GR86
Originally Posted by Racecomp Engineering View Post
What they said.
- Andrew
Would love to see the difference in lap time and feel between a stock gen 2 setup versus a gen 2 on gen 1 swift/billies.
Old 05-11-2023, 09:28 AM   #6
Guarantee the 2nd one would be faster...just the stiffer springs would make the difference. Might not be that much through.
- Andrew
Old 05-11-2023, 10:15 AM   #7
ZDan
ZDan's Avatar
Drives: '23 BRZ
What they said.
- Andrew
Hmm, I didn't realize that was an option...
Old 05-11-2023, 10:26 AM   #8
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
I'd be looking at the SS-1 or SS-2 if you're stating tenths of a second matter. I think you're leaving a good bit on the table just moving to lowering/stiffer springs. Also keep in mind that coilovers offer the ability to increase front camber, way more over stock.
So even if you're daily driving it you could run a good -3 or even -3.5 degrees whereas stock style struts and no upper camber plates or adjustability is only going to leave you with about -2.5 max with camber bolts installed. Also add in the ability to adjust rebound with coilovers.
IMO, the coilovers are going to offset the 80lbs you'd have to add.
If not, RCE Yellows paired with a good strut are common and a good setup. Yellows, Sachs dampers or Bilsteins, camber bolts running -2.5 camber up front.... that's about the max performance you'll get out of a strut setup before needing camber plates up front and rear LCAs, which might make you take more of a ballast hit in this class/format it sounds like.
Remember that it's less about the lowering and more about the stiffer spring rates that are going to actually help handling. You want some roll to load up the tires, but more than stock to keep roll in check and more equally distribute the weight, utilizing each tire more than just overloading your front outside.
cmiovino is offline   Reply With Quote
Old 05-11-2023, 11:18 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
For sure I'd get camber plates with lowering springs to get at least -3 up front.
Yeah, could be... On the '17 I ultimately added front/rear sways to the lowering springs/camberplates/Bilsteins, at that point it's only 1 additional suspension point (+40 lb. ballast) to get 1-way height-adjustable coilovers (with stock sways).
yeah, see above
I think I had about as good a "lowering springs + plates + Bilstein B8s" on the '17, and was overloading the outside front mid-corner. Thinking coilovers might address that not having outside front quite as hard on the bumpstop...
Old 05-11-2023, 02:50 PM   #10
RedReplicant
Drives: None
Can confirm the Mann Engineering bar doesn't fit the 2nd gen BRZ, but like you said, it uses spacers
RedReplicant is offline   Reply With Quote
Bilstein B6/B8 bump travel? Cut internal bumpstops? ZDan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-18-2018 02:47 PM
Ordering Bump Stops for TRD Lowering Springs PTR07-18130 MJones_RB Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 11-10-2017 07:56 AM
Standard Suspension Bump Travel 86•BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 87 07-26-2017 11:33 AM
FS: Like new Tein S-Tech lowering springs -1.4" Drop w/ Custom Bump Stops STS-V Brakes, Suspension, Chassis 6 07-31-2014 07:43 AM
Lowering springs and bump stops survey solidONE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-27-2013 11:23 PM
