Old 05-22-2018, 02:41 PM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
Bilstein B6/B8 bump travel? Cut internal bumpstops?
I'm on Swift BRZ Sport springs, 1.1"/1" drop. Does anyone know the bump travel with Bilstein B6/B8 struts and shocks?
I'd like to end up with at least ~6mm bump travel before hitting the internal stops starting from 1.1" lower-than-stock ride height up front. I'm guessing that will require cutting down the internal bump stops.
Does anyone have info on how much bump travel these struts have before hitting the internal bump stops?
TIA
Old 05-22-2018, 03:18 PM   #2
strat61caster
strat61caster's Avatar
Bilstein typically puts ~2" about bumpstop, maybe 60mm, idk I have B14's not B6/8.
According to this thread stock is 2.5" of bump travel, -1.0" means you're about a half inch into the bump stop already. Chop the bumpstop in half and you'd get approximately what you want.
http://www.ft86club.com/forums/showthread.php?t=26661
ineedyourdiddly
Old 05-22-2018, 05:10 PM   #3
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Is riding on the bumpstop so terrible? How much spring rate does it add?
Intent > Content
Old 05-22-2018, 07:31 PM   #4
strat61caster
Depends on the bumpstop, you can google some charts but it only takes a few tenths of an inch to start getting up over 100 lbs of stiffness.
The 86 is pretty bumpstop dependent even totally stock, and whether the lowering springs in question are designed with the additional spring rate in mind is pretty much down to the instructions.
Here's a chart from Koni, I don't know what an 86's stockers are, and only that Bilstein looks like they use a standard part for their struts.
I'm all for experimentation, cut it cleanly and reinstall the portion you took off if the user doesn't like it. Cheap mod that can have a noticeable change.
ineedyourdiddly
solidONE (05-22-2018)
Old 05-22-2018, 08:04 PM   #5
norcalpb
norcalpb's Avatar
RCE told me they are the same length as the bump stops provided with their spring set.
Old 05-22-2018, 11:35 PM   #6
solidONE
solidONE's Avatar
Good idear! If only someone had a spring rate gauge would throw these bumpstops in to do measurements.
The swift sport brz springs was the first thing I did to this car after camber bolts and I cut the bump stops. I felt it was a good mod, but never tested with the bumpstops intact. I did glue back the section I cut off when i remounted stock springs before selling them.
Intent > Content
Old 06-18-2018, 11:55 AM   #7
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Pretty much every shop out here will tell you to trim the Bilstein bumpstops when installing lowering springs. The bumpstop inside the B6s and B8s is pretty long. The car will drive significantly better with it trimmed.
I had Sprint Spec Rs and Bilsteins. Cut them in half and you won't look back.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 06-18-2018, 12:17 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
@Racecomp Engineering : any views on this based on your experiences with bilsteins? Any generic (if applicable) advises regarding them, if to cut, if-then by how much, or to replace with which?
Old 06-18-2018, 12:32 PM   #9
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Originally Posted by Racecomp Engineering View Post
This. Plus I'd take out the inserts and trim the bumpstop.
- Andy
Search function is great.
Old 06-18-2018, 12:52 PM   #10
Hmmm...I think I have to go back and edit what I said in 2015. The B6 and B8 have identical valving for one thing.
With Swifts I would trim the bumpstop. With our RCE Yellows, it is not required. Many people aren't comfortable opening up the Bilsteins and the car is still excellent with the standard bumpstops.
- Andrew
Old 06-18-2018, 12:57 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
And what if with stock, non lowering, springs?
Old 06-18-2018, 01:12 PM   #12
With stock springs no need to cut the bump stops.
- Andrew
Old 06-18-2018, 02:06 PM   #13
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
- Andrew
Wait, now you sign your posts Andrew instead of Andy? Time has changed you, man...
The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post:
CSG Mike (06-18-2018), solidONE (06-19-2018)
Old 06-18-2018, 02:47 PM   #14
The last 3 years have been a period of intense self-discovery.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
Calum (07-13-2021), CSG Mike (06-18-2018), Hyper4mance2k (06-18-2018), solidONE (06-19-2018)
TRD Bumpstops bassett27 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-24-2018 01:56 PM
Standard Suspension Bump Travel 86•BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 87 07-26-2017 11:33 AM
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 11:22 AM
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-25-2016 12:50 PM
WTB: OEM Tophats and Bumpstops RavioliG Want-To-Buy Requests 2 12-14-2015 12:56 PM
