| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
Drives: 2023 BRZ MT Sport Tech Black
High Altitude and Tuning
I'm in Calgary which is 1KM above sea level or about 60% of Denver's altitude. I can feel the thinner air zapping some power of my Gen 2 BRZ. Would tuning help alleviate this problem? Thanks.
Drives: 2018 Steel Toyota 86 GT Black
Well for starters you would need an aftermarket ECU I believe, and once you do that you would be voiding your warranty on your brand new car, not a good outlook!
#3 | |
Drives: 2022 Toyota GR86 Premium 6MT
i feel you though. uncorrected, my GR86 makes the same wheel horsepower as a stock FRS up here. this isn’t accurate. ecutek runs on the stock ECU. |
Drives: GR86
Ultimately the problem isn't entirely solvable by tuning. There's less oxygen (and everything) in the air at higher altitudes so without something to force more air into the cylinders you're going to see limitations.
I would assume the ECU correctly accounts for altitude by adjusting the fuel ratio accordingly, but less oxygen means you need less fuel for the same ratio, which means there's less power potential in each cylinder ignition. To regain that power you either need more air (forced induction) or more energetic fuel (like E85). This is actually one of the factors that made Hill Climb events interesting/challenging for participants. Simply tuning a car to be powerful enough to make it up a mountain without running like garbage at the bottom or the top was one of the deciding factors between winners and losers. Many if not most modern cars can adapt as elevation changes but physics is still physics. On any given air-burning fuel, the fuel can only do as much as it's supplied oxygen to do it. |
Drives: 2018 BRZ
Drives: Crapcan
It's less energetic by weight but the ratio is much richer which overall means the fuel charge does have more energy. A lot of the benefits of E85 come from other factors like latent heat of vaporization and knock resistance.
E85 also helps at elevation due to the oxygen it contains. IMO will be the most effective NA mod you can do if available.
2022 BRZ Build 2013 FR-S Build |
Drives: '04 STi, '12 Mazda 3 Hatch
I need one of you other high altitude owners to be the guinea pig and show us how clean and factory a FA24F swap can be done.
| Power at High Altitude | Lelandjt | BRZ Second-Gen (2022+) — General Topics | 37 | 08-25-2021 04:10 PM |
| High RPM high altitude drivability issue | MrSir | Issues | Warranty | Recalls / TSB | 8 | 04-20-2020 02:33 AM |
| Performance at high altitude | Buddhalite | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 11-06-2017 10:33 AM |
| High Altitude Turbo | mwjcyber | Forced Induction | 9 | 03-17-2016 10:55 AM |
| OFT E85 from low to high altitude | Kronos | Software Tuning | 10 | 03-30-2014 11:29 AM |
