Drives: 13' Subaru BRZ Limited SWP 6MT
High Altitude Turbo
At almost 6000 ft, according to altitude calculators, I'm getting 36 less bhp than someone at sea level. This has left me desiring something...more
![]() Altitude BHP calculator http://www.wallaceracing.com/braking-hp.php I've been contemplating NA upgrades versus boost, and have come to the conclusion that with my altitude the best bang for the buck would be with a turbo setup (turbo > supercharger for high altitude). Ideally I'd like a system that makes ~250whp on 91 octane, can't get 93 at this attitude, and doesn't require other component upgrades such as a clutch, injectors, pump, etc. From what I've read, turbos need to spool more at high altitude to compensate for the thinner air, thus increasing their heat and reducing their performance. I really like the AVO system, for its athletics and proven reliability, but I'm concerned about its performance at my altitude. Would something like the FA20Club 57 trim perform better than the AVO 18/49 at 6000 ft? Thus my question to the community is what turbo setup do you recommend for my altitude that will provide ~250whp? Thank you in advance! Last edited by mwjcyber; 11-16-2013 at 04:15 PM. |
#2 | |
Drives: UM86 - 6MT
Why have you already come to the conclusion that a S/C is inferior to a T/C at high altitude? Because of the parasitic nature of the S/C, therefore you're losing HP because of altitude and you're losing HP because of the S/C?
It seems as if a S/C would be better at high altitude due to the fact that boost would hit much sooner in the power band than a T/C. Per your quote, Quote:
Lastly, if close to sea level cars are dynoing around 160 whp, that means your getting roughly 124 whp - so you want to gain an extra 126 whp with a T/C - hmmm |
Drives: GBS BRZ
I live at 6700' out in the East Mountains, so I feel your pain. There is no good answer for getting back that 20%. You can always turn up the boost more to make up for the difference, but even with a 100% efficient intercooler, you will still run into the 91 octane problem and therefore still make less power than people running the same absolute boost pressure on 93 octane. There are a few E85 stations around ABQ, so if you are in town, that would help.
There is no difference at high elevations for the S/C versus the turbo argument -- that is, the arguments for S/C versus turbo are still the same arguments. The same rules apply as apply at sea level except that now you have to run more boost to make the same amount of power. As always, the turbos start looking better and better the more boost you run, and so that would be an advantage for the turbo IF you are turning up the boost further to get back that 20% loss. In a nutshell: both setups will be running higher effective pressure ratios, and so yes, the turbo will spool slower. But the S/C will have similar issues. Having said that, you could just accept your 20% loss, get the turbo or S/C kit, and have fun. At 8 psi boost in ABQ, you'll still be making significantly more power than a stock engine at sea level. |
Drives: 2013 "AVO Orange" FR-S
Technically, you don't have to turn up the boost on a turbocharger to compensate for altitude because it will do it for you. If you drive from 0 feet to 6000 feet, the boost pressure read by your boost gauge will show the same peak boost levels being reached. That's because the wastegate spring pressure doesn't change, and since it was calibrated for, say, 6psi, it will just bleed less and less air pressure off until it runs too far out of it's efficiency range. So if you were running at 6psi at sea level, it'll hold that 6psi to the mountains and back. In our particular case, the turbocharger is good up till 16psi, so you'd be very unlikely to run out of boost pressure up to typical elevations.
I know this because we tested at altitude, and I remember the drop in ambient pressure at 4000~6000 feet wasn't really that great, only 2~3psi I believe. So your 6psi at sea level setup would be running at 8~9 psi, and it should be ok up to 12 at the wastegate. |
#5 | ||
From the research I've done (lots of sites, even though I reference wiki), turbo's can provide engine performance similar to Sea Level, because at altitude a turbo will spin ever faster to compress the ever thinner air to achieve the original target boost. The limit here is the wastegate and the turbo's maximum rpm; of course the turbo takes longer to achieve the same boost levels since its having to reach higher rpm's, which means increased lag. So the main difference is that the supercharger will produce less boost with the same pulley combination up here than compared to sea level. Where as a turbo can spin faster to produce more boost (but not necessarily the same amount of power), a supercharger can't unless you change pullies to spin it faster. "A turbocharger remedies this problem by compressing the air back to sea-level pressures, or even much higher, in order to produce rated power at high altitude. Since the size of the turbocharger is chosen to produce a given amount of pressure at high altitude, the turbocharger is over-sized for low altitude. The speed of the turbocharger is controlled by a wastegate." Quote:
170whp/200bhp = 15% (drivetrain loss) 200bhp-36bhp = 164bhp at 6000ft 164bhp*85% = 139.4whp at 6000ft Either way, with your number or mine, that's considerably less than Sea Level; which is why I'm looking for more. |
#6 | |
I just found @gdrider77 's AVO "Stage 2" Build thread, and he's posted some impressive results with your system at Denver's altitude. http://www.ft86club.com/forums/showthread.php?t=39839 Back to my original post, I know a turbo will have to spin faster to meet it's specified boost psi level with thinner air at altitude; which means increased lag. That would lead one to believe a smaller turbo would be better to counter that increased lag, but then one would have to account for the increased rotational rate of the turbo, and can that same small turbo handle it. Thats what led me to question if I should be going for a larger turbo for my altitude, or if something like the Avo18/49 could handle it. Seems like this might be my answer: @gdrider77 's BRZ with AVO turbo running 8.5psi in Denver, tuned by "TheBoostCreepLtd" ![]()
#7 | |
Drives: GBS BRZ
So I don't see how the turbo can automatically compensate for the elevation unless you use a boost controller that has an absolute MAP sensor. A simple wastegate won't do it. If it did, your boost gauge should be reading something like 8-9 psi in the mountains (the boost gauge also reads gauge pressure, not absolute pressure). |
#8 | |
Sea Level 15psi (1 atm) + 6psi (boost) = 21 psi engine 6000ft 11.7psi (.78 atm) + 9.3psi (boost) = 21 psi engine Then only thing that makes me question this reality is looking at @gdrider77 's dyno charts. Other AVO setups with similar boost levels at Sea Level are making the same whp. How can that be? |
#9 | |
Drives: GBS BRZ
#10 | |
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Turbo at Sea level : 1bar + 0.5bar(boost) = 1.5bar Turbo at 1200m altitude: 1bar*0.86 + 0.5bar(boost) = 1.36bar Supercharger at Sea level: 1bar + 0.5bar(boost) = 1.5bar Supercharger at 1200m altitude: 1bar*0.86 + 0.5bar*0.86 = 1.29bar |
| High HP turbo catch can setup | Dan@AWD | Forced Induction | 32 | 08-06-2014 08:52 AM |
| Greddy turbo kit and AVO world turbo kit SPECIAL PRICING! | THMotorsports.com | Forced Induction | 129 | 07-24-2014 06:51 PM |
| 91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit | Unleashed | Cars for Sale/Trade | 8 | 02-20-2013 06:26 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
