Old 05-09-2023, 08:05 AM   #1
Sam86
Drives: Toyota 86 GTS
What happened to my OFT v2 data values?
Hi guys
I’ve had my OFT for 3 years, data values were always the same.
(Looked like this)
Anyway I did a data log, downloaded it to my PC but said NO when the open flash asked if I wanted to update.
My tuner did some changes to my tune using ecutek - said he didn’t touch my OFT and only unplugged it. I went to use my OFT to data log the new tune and saw it say something about scanning for PID (first time I’ve ever seen it so that) and then gave me these new data values
I checked the menu that shows values you can check and uncheck to show in the logging display but several values such as Boost, Knock corr, AFR and Command AFR are completely missing.
I plugged my OFT into my pc and updated it fully but still see these same new values.
Anyone know how to get the old values or whether this has happened to their OFT too??
Sam86 is offline   Reply With Quote
The Following User Says Thank You to Sam86 For This Useful Post:
Clipdat (05-09-2023)
Old 05-09-2023, 06:46 PM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Possible pattern/related: https://www.ft86club.com/forums/show...2&postcount=68
Originally Posted by humfrz
I'm old and lazy
Sam86 (05-09-2023)
Old 05-09-2023, 09:45 PM   #3
Sam86
Seriously �� the one time I need to do logs and it happens to be during a forced update…
For my personal reference, I did my log and plugged into my pc exactly 1 week ago from today. I only turned on my OFT and realised it was different 2 days ago
I’m also not in the US…
Old 05-10-2023, 04:18 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Could just be a coincidence then and more related to the updated tune you got? Not sure.
I'm old and lazy
Old 05-10-2023, 11:08 PM   #5
Sam86
That’s why I made the thread as I’m slightly suspicious.
My tune has been very bad, and my tuner was a little annoyed that I was doing logs on my own to try and diagnose my issues. He said he didn’t touch my OFT at all and all he did was make minor timing adjustments to my ecutek tune however I found it very coincidental that the main values that are probably the most important for me to log (boost, knock and AFR) are no longer displayable when I went to log later in the day from when he adjusted my tune
My OFT was my only way of data logging
He has done 3 seperate tune adjustments to my car prior and they never had any impact on my OFT values
Old 05-11-2023, 03:16 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Yes, very interesting. Even if he doesn't like the OFT, I doubt he would even physically be able to do anything to block its datalogging functionality.
Unfortunately this is getting to be above my pay grade, so paging @tomm.brz
I'm old and lazy
Old 05-11-2023, 03:27 PM   #7
tomm.brz
Drives: brz 2017 hksv2
i m no oft expert, @AussieBRZ is
Old 05-11-2023, 03:34 PM   #8
Clipdat
Proud of BOXER
Clipdat's Avatar
Oh well worth a try
I'm old and lazy
Old 05-13-2023, 10:29 PM   #9
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Don't use Tune Bot option go through my car then
diagnostics
Check you have correct vehicle selected
AussieBRZ is offline   Reply With Quote
Old 05-14-2023, 04:17 AM   #10
Sam86
diagnostics
Well it seems to be working again?
I’ve never used the tunebot tab, I don’t even know what it does, I’ve always gone through my car->diagnostics->real-time data display to see my values. Don’t know why it was acting up the first few days after my reflash hopefully it stays showing the correct values
Old 08-05-2023, 03:47 PM   #11
J95
J95's Avatar
The same happened to me. I am missing a lot of values after a forced update of the OFT software
I only checked "tune boot" option, so I will check this diagnosis tab
J95 is offline   Reply With Quote
Anyone figured out where to get the CAN bus data for AIM/etc. data loggers? timurrrr BRZ Second-Gen (2022+) — General Topics 47 07-31-2024 03:10 PM
OFT STAGE2+ BRZ VALUES LTFT GarrettGalway Software Tuning 3 08-11-2018 11:39 PM
series.blue used values why? BRZ First-Gen (2012+) — General Topics 48 08-24-2015 12:28 PM
BRZ Values Apex_BRZ BRZ First-Gen (2012+) — General Topics 20 10-16-2014 05:38 PM
Safe values? mike_ekim1024 Software Tuning 12 11-05-2013 01:19 PM
