Drives: Toyota 86 GT
Oil analysis advice
Hi yall,
My oil analysis at 15k miles about 4000 miles on the oil, and here are the results: blackstone says the copper is high. I track/autocross it about 10 times a year, and daily it as well. Any advice about what to do in the future? Shorter oil change interval/Longer oil change interval/More frequent/5W30 for track season? |
ProCrastinationConsultant
once is an anomaly, 2-3 times is a pattern.
do you go extremely easy on it until it's fully warmed up, or do you just send it all the time?
"Just send it bro". Jk, Jk, I take it easy until it hits 195F on the gauge.
This is not a bad report. 5 Parts per Million of copper is still nothing to get excited about. What brand oil?
If you auto-x 10x on that oil, I'd step up to something like Motul 300V 0w-20. The fuel is more concerning to me as it impacts the oil quality. Typically, high fuel is a result of excessive cold idle, and can be resolve by changing that habit. Start the car and go, just avoid high load until your oil is up to temp. It can also be the result of very short drive cycles. By short, I mean 1-2 miles where not even the coolant gets up to temperature. |
#5 | |
Drives: Toyota GT86
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#6 | |
#7 | |
The Dictater
Drives: '13 Red Scion FRS
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" |
#8 | |
No. Load is what tries to squish the oil film from between bearing and pin. Low load (torque) does not apply nearly as significant a force.
Low RPM load puts significantly more strain on rod bearings. Each rod carries twice as much load making 100 ft/lbs at 2,000 RPMs vs 4,000 RPMs. At 4,000 RPMs that torque is spread over twice as many combustion cycles, meaning the rods get half as much load. |
How does one avoid high load?
#10 |
Drives: 2013 FR-S Series 10
Be in the right gear for conditions. I.e. dont try to go uphill in 6th gear at 40mph.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
#11 |
not playing cards
Drive it as if the gas pedal can't be pushed more than a quarter way down... -ish.
The car ends up slowing down going uphill even though the engine is revving in a lower gear, and it takes extra time getting up to speed.
#12 |
Drives: 2017 BRZ w/PP
I never had copper in my oil but if you autocross I would highly recommend 5w30 at least until it gets cold out.
#13 | |
Drives: Toyota GT86
Using Mobil 1 super3000 5w-30 XE-1(euro stuff) lol
#14 | |
I actually went back and checked no my old engine since i just got my trucks oil back and i did have some. Id still recommend the heavier oil if you autocross tho |
| Oil Analysis - 1st oil change | R L Newb | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 375 | 11-19-2021 09:24 AM |
| Oil analysis | JIM THEO | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 11-14-2018 06:42 PM |
| Analysis Paralysis | athos56 | BRZ First-Gen (2012+) — General Topics | 98 | 10-08-2017 10:04 PM |
| Blackstone Oil analysis at 52k/45k/37k | strat61caster | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 07-06-2017 12:26 PM |
| Used Oil Analysis @ 51k miles | 8RZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 29 | 04-21-2017 07:35 PM |
