Old 04-20-2023, 09:34 AM   #1
ekaunt
Drives: 2022 brz
Where is ground by fuse
I installed a dash cam and hardwired it to the fuse box by the driver side, but I can't figure out how to connect the ground.
I attached the ground cable to the screw of the fuse box as you can see in the image, but it keeps disconnecting non stop.
Does anyone know where there's a proper ground point near the fuse box and how can I connect a wire there? thanks
ekaunt is offline   Reply With Quote
Old 04-20-2023, 10:16 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
I used the same bolt as you, but I put the ground connector on the back side (i.e. behind the plastic and touching the metal the bolt goes into). This works fine for me.
In general all metal parts in a car are grounded so any bolt that goes into metal should be good.
Ohio Enthusiast is offline   Reply With Quote
Old 04-20-2023, 10:41 AM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I grounded on the metal frame under the dash immediately to the right of this fuse panel. There are bolts all set and ready to go.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Old 04-20-2023, 06:59 PM   #4
ekaunt
Drives: 2022 brz
which direction is right? can you please circle it in this pic 😓👉👈
Dashboard fuse box - mini fuse removal airrick Electronics | Audio | NAV | Infotainment 0 10-25-2019 05:05 PM
A bit closer to the ground Toyology Member's Car Journals 10 09-19-2016 10:06 AM
ugh. ground clearance. perryair BRZ First-Gen (2012+) — General Topics 62 02-18-2016 12:10 AM
Constant 12v/Ground? 636 Electronics | Audio | NAV | Infotainment 0 04-01-2014 02:59 AM
Ground clearance? RT87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-28-2012 04:13 PM
