Old 04-19-2023, 08:31 AM   #1
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Fumoto valve and residual oil
Last weeked i had to pull my engine. I drained the oil from the Fumoto valve. After a bit, I decided since the valve might get bumped during the engine removal and transport, I took the valve out to replace it with a regular oil plug.
There was quite a bit of residual oil still in the pan. 1-2 cups?
And yes, I need a new drop light.
Old 04-19-2023, 09:14 AM   #2
Joon525
Joon525's Avatar
Drives: 2016 BRZ
If I remember correctly it's because the threads of the valve itself stick up a little bit inside the pan.
Years ago on an LGT forum someone actually cut a notch in it so more drained out.
Joon525 is offline   Reply With Quote
Old 04-19-2023, 12:49 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I cut mine down to the depth of the female threads.
And that drop light is just fine.
Old 04-19-2023, 12:54 PM   #4
KillerBMotorsport
KillerBMotorsport's Avatar
Yep. Guys do all kinds of things to get that last bit out. Notch the bottom, drill a hole, grind some threads off jack or ramp on one side to tip the car... The press formed thread insert also protrudes into the pan + 3/8". So even without the Fumoto, you're leaving a good bit in there. More than a cup, but probably not two?
Glad to see the New WRX FA24's pan has a better boss that's extended outward. Looks to have machined threads (vs formed) and there are more threads as well.
WRX top left, BRZ on the right...
How much of this really matters? Probably very little since at an oil change, you have almost a quart suspended in various places in the engine anyway. Just another reason to be vigilant with oil changes.
KillerBMotorsport is offline   Reply With Quote
Old 04-19-2023, 01:35 PM   #5
Ohio Enthusiast
Drives: 2018 BRZ
Add an oil cooler and you have a whole additional quart not being drained.
Ohio Enthusiast is offline   Reply With Quote
Old 04-19-2023, 03:35 PM   #6
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
And the unasked question. Does it matter??
General answer. Probably not. I change mine on a warm engine primarily to ensure that the oil is well mixed.
Even on an in-line vertical cylinder engine I never got all of it. On an “H” configuration? Fuggidaboutit
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 04-19-2023, 07:32 PM   #7
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
unless you're doing UOA at every interval its not super important.
more important is regular maintenance as needed.
Old 04-19-2023, 08:33 PM   #8
Ultramaroon
not playing cards
so, wait. is it regular maintenance, or as needed?
Old 04-19-2023, 09:41 PM   #9
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Regular maintenance, as needed.
Originally Posted by humfrz
I'm old and lazy
Old 04-19-2023, 09:58 PM   #10
Ultramaroon
not playing cards
Mine regularly needs maintenance.
Old 04-19-2023, 10:01 PM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
Same.
I'm old and lazy
Old 04-20-2023, 06:55 AM   #12
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I uh... I do them at every interval. Done them since the car was new and put the fomoto valve in about halfway through the life of the car so far (45k miles). The extra oil that doesn't make it out... doesn't seem to make a difference
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 04-20-2023, 11:06 AM   #13
KillerBMotorsport
We tee in a drain valve, or if access is easy, just pull the lower line. OEM coolers tend to be more user friendly with a drain and decent access. Wish more aftermarket coolers did the same.
Old 04-20-2023, 11:08 AM   #14
KillerBMotorsport
No. It's a fraction of what's remaining in the engine anyway.
Oil changes/Fumoto valve... CincyJohn BRZ Second-Gen (2022+) — General Topics 39 05-30-2022 08:48 PM
FS: Fumoto Valve w/ Lock byun Engine, Exhaust, Bolt-Ons 1 06-13-2016 11:03 PM
FS: Fumoto Valve jvenetto Engine, Exhaust, Bolt-Ons 6 10-01-2015 07:16 AM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 12:06 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 01:51 PM
