Old 04-17-2023, 01:44 PM   #1
MJones_RB
MJones_RB's Avatar
MAF Sensor cleaning
My FR-S is nearing 60k and the idle is a little rough at times. Decided it's time to clean the MAF sensor and reset the ECU. Picked up this stuff (there's really only a couple different brands that offer MAF cleaner). Has anyone else done this with any positive results? Thanks
MJones_RB is offline   Reply With Quote
Old 04-17-2023, 02:58 PM   #2
tomm.brz
Drives: brz 2017 hksv2
do it)
Old 04-17-2023, 06:56 PM   #3
Grady
Grady's Avatar
If you use 4 cans you could get another 40 horse power!
Old 04-17-2023, 08:44 PM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I'd never done it in 11 years, so I figured I'd try it.
Made no difference.
Saw some people also get a throttle body cleaner ... I intend on doing. ... When I'm not feeling like a lazy mut.
Old 04-17-2023, 09:34 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
It can only help if the MAF sensor really was dirty. The only reason I can think would be from oil coming off of one of those reusable elements.
Old 04-17-2023, 10:12 PM   #6
Kaotic Lazagna
Drives: GR Corolla
Have you changed your spark plugs? iirc, they're due to a change at 60k. Unless you are using an overly oiled air filter, my guess is your idle hiccups are from the plugs.
Old 04-17-2023, 10:22 PM   #7
Ultramaroon
not playing cards
My gut says MAF before plugs. I'd check LTFT at idle before cleaning MAF and also would watch STFT immediately afterward. @tomm.brz, amirite?
Old 04-17-2023, 10:56 PM   #8
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I use CRC MAF Cleaner. I don't have any specific issues, and haven't run into any issues (with the car or the product). Just part of regular maintenance every other oil change since I have an oiled filter
130k miles on ODO. Spark plugs every 60k miles, got "new" old coil packs at 120k
EndlessAzure is offline   Reply With Quote
Old 04-18-2023, 01:47 AM   #9
tomm.brz
no real need to look at stft unless it is like pegged hard to either too negative or too positive values.. in that case it will shortly transfer it to ltft anyway
Cleaning a maf is never a bad idea, specialy if you have the specific cleaner that is safe to use on it
Old 04-18-2023, 08:38 AM   #10
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Just spray the element. Do not touch it.
I’ve always run oiled K&N drop-in filters since 1988 and periodic (annual) sensor cleansing has been part of my maintenance routine.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 04-18-2023, 10:29 AM   #11
wbradley
Sarcastic SOB
wbradley's Avatar
I need to clean the MAF sensor at least once per season with using an HKS mushroom intake. At some point it has sucked in some oil and it took me a while to discover that a dirty MAF was THE reason my car wasn't running as it should. It is best to remove the intake section with the sensor and spray it really good outdoors in a well ventilated area.
Old 04-18-2023, 01:13 PM   #12
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Coil packs are a big one, the front passenger one tends to go out because its so close to the header.
I also found my car to be smoother with a newer battery .. but that was when the batteries were on their last leg (+5 years of use)
Old 04-18-2023, 01:42 PM   #13
MJones_RB
MJones_RB's Avatar
I haven't yet. I know they are due at 60k but some say they should be good for 120k. Thanks!
Old 04-19-2023, 08:02 PM   #14
Teseo
Drives: frs
Its called High flow performance air filter. Worth the extra 3HP. I would rather replace pcv than touch any electrical stuff
P0140 Oxygen Sensor Circuit No Activity Detected (Bank 1 Sensor 2) Help Johnders2586 Issues | Warranty | Recalls / TSB 9 04-04-2023 03:32 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
