Old 04-16-2023, 08:41 PM   #1
Mont-E
Drives: Scion FR-S
Broken strut spring
I was trying to diagnose a noise when driving on bumpy roads and I noticed this (see attached pics).
The red encircled part, that's where the end of the spring should be, correct?
Any recommendations if I should just get the spring replaced or replace the whole strut assembly?
Mont-E is offline   Reply With Quote
Old 04-16-2023, 09:21 PM   #2
norcalpb
norcalpb's Avatar
Yeah the red circle is where the spring should be sitting lol.
Everything. Replace everything. It looks like the previous owner tried to lower the car ultra ghetto style but maybe it slipped? Never seen that before.
Old 04-16-2023, 10:24 PM   #3
Mont-E
Drives: Scion FR-S
Did not think about that.
There is also a broken piece so it's not just the slip.
Old 04-17-2023, 03:09 AM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Wow, that's a broken spring. Crazy. Must've been some very rough roads.
You're looking at a new OEM strut and spring assembly, as the damper likely got damaged from being used without a functioning spring.
Maybe someone local is selling a set for cheap if they recently upgraded to coilovers?
Originally Posted by humfrz
I'm old and lazy
Old 04-17-2023, 07:09 AM   #5
If you are anywhere near London I have a whole set of FRS springs with 10 kilometers on it you can have.
Old 04-17-2023, 09:12 AM   #6
Racecomp Engineering
And/or rust.
- Andrew
Old 04-18-2023, 05:12 PM   #7
Mont-E
Drives: Scion FR-S
I am in BC.
I wonder if I can just replace the spring instead of the whole assembly? I think it would be the labor costing the bigger chunk of the cost and I am assuming that the spring replacement would be significantly cheaper.
Old 04-18-2023, 05:21 PM   #8
Originally Posted by Mont-E View Post
I am in BC.
The whole works has to come off anyway to replace the spring.
Old 04-18-2023, 07:07 PM   #9
norcalpb
norcalpb's Avatar
I am in BC.
The spring can support the shaft of the strut when taking corners, but your spring is providing 0 support which means the strut might be compromised. It’s not hard to damage them.
I’d personally only replace the front top hats/springs/struts now and do the rears down the road. As long as they are BONE DRY.
Used suspension from a 2017-2020 brz or 86 ~ $250
Install for just the fronts ~ $200
4 wheel Alignment ~ $80
Old 04-18-2023, 08:18 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Racecomp Engineering View Post
And/or rust.
- Andrew
Stress corrosion cracking + fatigue most likely. Typically most common failure mode of springs as they age. Not that there isn't a dozen things that can go wrong during the manufacturing process. Hydrogen embrittlement from base metal corrosion, martensite embrittlement during tempering, too high quench temperature, too hard, held to long below phase transition temp before quenching, ect.
Old 04-19-2023, 01:29 AM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
I better sell my car before it crumbles.
Old 04-19-2023, 10:23 AM   #12
Old 04-19-2023, 11:20 AM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think I would be more concerned with Yellowstone erupting or the Cascadia Subduction zone causing a massive earthquake. Or aliens.
Old 04-19-2023, 11:52 AM   #14
Ultramaroon
not playing cards
That's it! I'm going back to bed.
Broken strut bar mount Jonsey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 02-04-2022 01:33 AM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
Kartboy short shifter broken spring magicchef Engine, Exhaust, Transmission 1 01-24-2018 02:41 AM
Need Advice: Broken strut mount stud... cobrabyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 12-22-2014 04:37 PM
WTB RCE spring or RS*R spring mounted on stock strut jshum Want-To-Buy Requests 1 10-11-2013 02:47 PM
