Old 04-14-2023, 08:21 AM   #1
Farrisj25
Drives: White
Clutch gets soft at high rpm’s
What’s up everyone! So recently I replaced my clutch got the car started car drives fine now other than one concern! Between 2-4 gear at high rpm’s when I’m cruising the clutch decides to have low resistance at the top of engagement. It shifts fine during this process. When I’m lower in the Rpm’s I don’t have this problem. Would this be a symptom of having air in my lines and need to bleed the air bubbles out? There’s no grinding in my shifts and such so I’m just curious what’s causing this issue!
Farrisj25 is offline   Reply With Quote
Old 04-15-2023, 05:49 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
what parts where replaced with the clutch? what clutch was used?
Soft clutch? Simok Engine, Exhaust, Transmission 6 11-20-2020 08:15 AM
Soft clutch? Simok Engine, Exhaust, Transmission 0 11-18-2020 09:10 PM
Clutch feels soft? Easier? NJNCFRS Engine, Exhaust, Transmission 8 03-02-2018 10:54 PM
High Performance Clutch FR-Shred Engine, Exhaust, Transmission 6 11-09-2015 04:32 PM
Soft Clutch fix Billy2224 Cosmetic Modification (Interior/Exterior/Lighting) 10 07-01-2012 05:03 PM
