Drives: Toyota GT86
To reuse or not to reuse
After reading some not so great things about Motul gear300 in our transmission I decided to swap it out for AMSOIL Synthetic Manual Transmission and Transaxle Gear Lube
When I put in the gear300 6 months ago I used brand new oem washers.... So should I buy new washer again or just send it ? Thanks
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
#2 | |
Proud of BOXER
Drives: Subaru Boxer
Always use a new washer.
Drives: FR-S,GTI
I know that the crush washer manufacturer's lobbyist group says to change the washer every time. But I don't. I did the first time out of an over abundance of caution. But I've reused the washers ever since. I've change the tranny and diff 3 times and the oil many, many times reusing the washers and never leaked a drop.
But Hey, it's your car. |
#4 | |
Drives: Toyota GT86
O rings, crush washers it is good to replace every time. It is overkill lets face it worst thing that will happen is you will have an oil seep.
Drives: Toyota GT86
I ordered 2 new washers with my dealer today. I was not man enough to risk it lol
#7 | |
Drives: 2020 BRZ PP
This is the first I've read about Gear 300 not being good for our trans'. Do you have a link to that particular discussion? |
#8 | |
Drives: Toyota GT86
I found more than one posts about it... Most people seem to switch over to redline MT-90 and Amsoil which are both GL4 only fluid. I am nervous enough about blowing 2nd gear on track that I don't need to worry that the oil I use might be causing issues as well.
Drives: None
I've been happier on the MT90 over the Gear 300 anyway, it seems to shift better before everything is warmed up
#10 | |
Drives: Toyota GT86
What are you running in the diff ?
#11 | |
Drives: None
It has an OSGiken in it but I've been running Motul Gear Competition 75W140 since it is on the approval list.
#12 |
Drives: Toyota GT86
Ah okay. Thanks . I will make sure to post my impressions but as like as the gear box doesn't grind or blow up on track I will be happy lol
#13 |
Drives: Toyota GT86
Just quick update... Really loving the Amsoil so far glad I switched. Check out the build thread if you want more details.
| Clean and Reuse your Cabin air filter | stevesnj | DIY (Do-It-Yourself) Guides | 15 | 06-25-2016 08:15 PM |
| Reuse or get new exhaust hangers? | Atticus808 | DIY (Do-It-Yourself) Guides | 5 | 01-24-2016 06:15 PM |
| aux input reuse? | pandora | Electronics | Audio | NAV | Infotainment | 0 | 08-09-2013 03:14 PM |
| Reuse your microfiber towels? (on your paint) | Nate219BRZ | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 07-30-2012 11:16 PM |
| Reuse the standard scion HU? | motofan | Electronics | Audio | NAV | Infotainment | 0 | 06-18-2012 04:56 AM |
