Old 03-31-2023, 07:53 PM   #1
autosenses
autosenses's Avatar
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
Suspension setup for Limerock
Hey everyone,
I need a little help to get an idea what alignment setup I should start for this season.
I'm going to do a season at Limerock's AutoX which is the official FCP Euro Proven grounds.
I know I have limited adjustment with stock suspension, but what alignment numbers should I be looking for? I have 17x8 45's RPF1's with 225 RT660's & camber bolts (not installed yet).
Any help is appreciated.
autosenses is offline   Reply With Quote
Old 03-31-2023, 10:18 PM   #2
strat61caster
strat61caster's Avatar
Max front camber whatever it is, -1.5 ish at best depending on which bolts you got. Zero toe front, 1/16” in at the rear. Can’t do anything else have fun.
ineedyourdiddly
Old 03-31-2023, 11:57 PM   #3
jflogerzi
jflogerzi's Avatar
More camber could help. Peddler top hats would add another degree of camber
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Old 04-02-2023, 05:43 AM   #4
autosenses
autosenses's Avatar
I have SPC camber bolts. These ok? Other bolts better or offer more angle?
Thanks for the help!
Old 04-02-2023, 01:45 PM   #5
strat61caster
Sure, check this thread out. FYI aftermarket camber bolts bump you out of d street if your club follows scca classing.
https://www.ft86club.com/forums/showthread.php?t=103609
ineedyourdiddly
Old 04-03-2023, 06:08 AM   #6
autosenses
autosenses's Avatar
Thanks.
So my SPC bolts will give me a max of 1.75? I thought its capable of 2.5? Either way, think 1.75 is a good start.
What should I expect for tire wear?
Old 04-03-2023, 08:06 PM   #7
strat61caster
Thanks.
Depends on which bolt you got 14 or 16mm, it’s in the thread.
Rear should wear decently even, you’ll chew up the outside edge of the front tire a noticeable amount, rotating front to back will help but you may consider flipping the tires on the wheels to squeeze a few more events out of them.
ineedyourdiddly
Old 04-04-2023, 05:47 AM   #8
autosenses
autosenses's Avatar
Your right it is in the thread- just read it again. SO much information! I love it.
I think I got 14? this is the SPC model number SPC81305
https://www.ftspeed.com/part/81305-s...1#.ZCvxZHbMLEY
Air Suspension Setup nwgabrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-08-2022 03:31 PM
Suspension setup hpde_addict Tracking / Autocross / HPDE / Drifting 12 11-17-2017 04:26 PM
Suspension setup hpde_addict Northern California 0 11-08-2017 05:52 PM
Different Suspension setup on BRZ? Trmx2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-13-2013 08:36 PM
setup of suspension jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-21-2012 03:03 PM
