Old 03-23-2023, 01:53 PM   #1
Danny318
Drives: 2019 BRZ
What other subaru models rear sway bar fit brz/frs
Some of the OEM bars are the same as ours, like wrx for example. Possibly forester as well. Does anyone know what years and what models will fit?
Also does anyone know of those models, which have 17mm or 18mm rear bar?
Danny318 is offline   Reply With Quote
Old 03-23-2023, 01:58 PM   #2
norcalpb
norcalpb's Avatar
2008-2014 STi has an oem 18mm bar that fits our cars.
Not sure what size the 2015-2022 has.
Old 03-23-2023, 03:37 PM   #3
yberther
yberther's Avatar
Drives: '13 SWP Limited
2013-20?? impreza has the same rear subframe as the twings, so all the bars can be swapped between the impreza, wrx, and sti
I'm currently running a 2014 impreza bar that is a tiny bit stiffer than the stock one.
yberther is offline   Reply With Quote
Old 03-24-2023, 02:30 PM   #4
RedReplicant
Drives: None
Are there any stock bars that are smaller than the BRZ/FRS/86 that fits? (Mann Engineering alternative)
RedReplicant is offline   Reply With Quote
Old 03-24-2023, 04:56 PM   #5
SCFD
The closest I can think of is Cusco. It's the same size as 13-16 14mm sway bar except it's hollow so it'll be softer.
SCFD is offline   Reply With Quote
Old 03-24-2023, 05:27 PM   #6
norcalpb
norcalpb's Avatar
I believe that somehow (material, bends, etc) the Cusco 14mm is stiffer than the oem 14mm.
Old 03-24-2023, 05:32 PM   #7
norcalpb
norcalpb's Avatar
Unfortunately none. The 2004 legacy b12 has a 13mm bar but it’s a different shape than ours.
I saw an outback sport the other day and it didn’t have any endlinks where ours normally are. I thought that maybe it doesn’t come with a rear bar (which would be the softest option), but turns out they put it in an insanely difficult place to see/access.
"The rear stabilizer is now attached directly to the body of the car. Removal of the rear stabilizer bar requires removal of the rear sub frame and all related components."
Old 03-25-2023, 07:07 AM   #8
makinen
makinen's Avatar
Drives: Toyota 86
Refer this link:
https://www.ft86club.com/forums/showthread.php?t=28221
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 03-25-2023, 02:08 PM   #9
Racecomp Engineering
It's listed as 73% as stiff as the factory 14mm solid.
- Andrew
Old 03-25-2023, 10:06 PM   #10
norcalpb
norcalpb's Avatar
- Andrew
Well I stand corrected. That should make it the only option besides Mann Engineering that is softer than stock.
Old 11-27-2023, 06:32 PM   #11
RedReplicant
Drives: None
Coming full circle on my question here but
Karcepts
Top to bottom:
2017+ 15mm
<=2016 14mm
Mann Engineering 13mm
Some fitment notes:
Mann bar won't fit the 2nd gen BRZ
Karcepts bar will require some trimming of the bolts and a thin nut with 8" springs + helpers, or switching to 7" springs, this is an uncommon setup
Rate data from Karcepts:
WRX rear sway bar: good front sway bar combo? LerpK Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2016 06:02 PM
WTB: Rear sway end links or sway bar with endlinks JoeBoxer Want-To-Buy Requests 1 08-03-2015 01:20 PM
Subaru isn't currently planning a BRZ STi or other performance models vh_supra26 BRZ First-Gen (2012+) — General Topics 28 04-26-2014 04:18 AM
Subaru Starlink for 2014 Models Bristecom Electronics | Audio | NAV | Infotainment 1 01-08-2013 04:25 AM
