Old 03-16-2023, 10:21 AM   #1
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Brembo GT Brakes are LOUD! Any other Brembo GT users have experience?
I installed the Brembo GT brake kits front and rear on my car a few months ago. As soon as I installed them, I noticed they squealed very loudly when applying medium pedal pressure. I figured the noise was just because they were new pads and it would subside over time. It has been several months now and ~500 miles, but they are just as loud as ever. I know they are racing brakes, but the squeal is very loud. I am sure other cars on the road can notice.
I found this video where they apply grease to the shims on the Brembos on a Scat Pack to make the noise go away:
I didn't apply any grease during installation. I guess I assumed it would already be greased because the calipers/pads/etc came per-assembled. However, I am not sure this should even be necessary. The noise coming from the Scat Pack Brembo's is not nearly as loud as mine.
I contacted CSG and they said it is the pads. They suggested switching to Project Mu Type-PS pads to reduce the NVH. But they noted that these pads will have considerably less performance than the currently installed Brembo pads. This is not a track car, it is my daily and I do a few Auto-X events per year with it. So I am concerned about performance, specifically initial bite, so I would rather not have to downgrade the pads if I don't have to.
I know the Brembo GT kits are popular here. Do any other users have experience with this issue? Did you apply grease to the pads/shims? Did the noise eventually go away?
Pics for attention:
Old 03-16-2023, 11:51 AM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Did you bed in the pads properly after the initial install?
Originally Posted by humfrz
I'm old and lazy
Old 03-16-2023, 04:08 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What pads are you on now? Some are just loud no matter what you do.
Old 03-16-2023, 07:37 PM   #4
Xed32
Drives: '22 brz Sport-Tech
"daily and I do a few Auto-X events per year " = Fedoro DS2500
Xed32 is offline   Reply With Quote
Old 03-16-2023, 08:25 PM   #5
Mike_ZN6
Mike_ZN6's Avatar
The pads that came with the Brembo GT kits. I think they are called Brembo Dual Purpose.
Old 03-16-2023, 08:26 PM   #6
Mike_ZN6
Mike_ZN6's Avatar
Do they make Fedoro DS2500 pads that fit the Brembo GT calipers?
Old 03-16-2023, 09:31 PM   #7
Xed32
which GT are you running?
1H4.6005A
1H1.7003A
Old 03-16-2023, 09:46 PM   #8
spike021
spike021's Avatar
Does it only happen while they're cold or even after several miles / minutes of driving + braking?
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 03-16-2023, 10:05 PM   #9
Mike_ZN6
Mike_ZN6's Avatar
Looking over the manual, it suggests 20 60mph - 20mph stops and 10 stops from 80 mph. I only did a handful of ~60mph - ~20mph stops after initial installation. I can try and follow the full procedure and see if it helps. It is difficult to find somewhere to attempt this around here. Hopefully it is not too late.
Old 03-16-2023, 10:07 PM   #10
Mike_ZN6
Mike_ZN6's Avatar
1H4.6005A
1H1.7003A
Front: 1H5.6005A1
Rear: 2E5.5003A1
Old 03-16-2023, 10:08 PM   #11
Mike_ZN6
Mike_ZN6's Avatar
It seems worse when they are cold but the squeal persists after prolonged driving. It does not help that it has been winter up here the entire time they have been installed.
Old 03-16-2023, 10:58 PM   #12
spike021
spike021's Avatar
My guess is the cold affects it too. My brembos with endless pads definitely make noise for longer this time of year and this is California. During warmer months it depends on if the brakes have been in the sun or not.
Old 03-16-2023, 11:05 PM   #13
Xed32
Assuming its the CSG spec GT (1H4.6005A I think?). Then the CSG Spec CP pads are supposed to be comparable to the Fedoro DS2500.
Old 03-17-2023, 01:26 AM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
Looking over the manual, it suggests 20 60mph - 20mph stops and 10 stops from 80 mph. I did only did a handful of ~60mph - ~20mph stops after initial installation. I can try and follow the full procedure and see if it helps. It is difficult to find somewhere to attempt this around here. Hopefully it is not too late.
That is an above average amount of bedding required, but makes sense for this caliber of BBK.
It is not "too late" by any means, you can try the bedding process again at your leisure. However, I agree with your assessment, it'll be tricky to find a place where you can safely do those 80 to ~5 stops.
Also, it's kinda nerve wracking since you're supposed to brake extremely aggressively, just before the point of engaging ABS. Many people aren't comfortable braking that hard and feeling the forces. IMO, and speaking from experience, it can be kinda disconcerting.
Anyway keep us updated if you decide to give the bedding a go or switch up the pads.
I'm old and lazy
CSG Brembo Brakes LenA Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 07-12-2024 10:05 AM
Project Mu 999 pads for Brembo brakes or brembo BBK. Still sealed in the box. $200 Jstyle Brakes, Suspension, Chassis 3 06-13-2022 12:23 PM
WTB: OEM Brembo Brakes or BBK lc300 Canada Classifieds 13 11-03-2021 09:29 AM
Evo X brembo brakes Justkiz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-12-2013 02:00 AM
