Old 03-12-2023, 06:37 PM   #1
gkanga
Drives: 2014 FRS
Transmission removal woes
I'm in the middle of trying to get my transmission out to replace the throwout bearing, clutch, flywheel, etc. I got everything disconnected and unbolted without too much trouble. The transmission slid off about 3/4" and is stuck there. One of my friends and I spent about 8 hours yesterday screwing around with it... jacking up the engine a little... jacking up the transmission a little, lower them, raising, prying all over the place. No luck.
As far as I can tell the alignment is good. I have some 1x2 wood scraps at the top, bottom left, and bottom right so I know the gap is even all the way around. That should mean they are parallel. I stuck one of the bolts back through to make sure it's not off center left/right or up/down. It threaded right into the engine with no trouble so I think that's good.
I don't know why it isn't coming out unless the pilot bearing or spline on the clutch disc is messed up and stuck or something.
My next step is going to be to cobble together some screw mechanisms to force them apart with a nut.
I attached a couple pictures. One shows the gap at the top, the other is with a little snake camera I got inside.
Any ideas??
Thanks
gkanga is offline   Reply With Quote
Old 03-12-2023, 07:16 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i would push it forward onto the shaft slightly and try to jerk it back to try to overcome any bad/worn/grease spots that might be preventing full removal.
Old 03-12-2023, 08:04 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
You have to support the front of the engine AND the back of the transmission! Why do you have a block stuck in the top? You probably warped the friction disc as soon as you managed to pull the transmission far enough to disengage the pilot bearing. About 3/4"
Opie (03-14-2023)
Old 03-12-2023, 08:20 PM   #4
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
I got mine off by supporting the engine on the pan with a block of wood and then using a transjack to put it up a bit higher than normal and split it with a pry bar. Putting it on both times took 2 hours and 3 respectively.
Breadman is offline   Reply With Quote
Old 03-12-2023, 08:33 PM   #5
gkanga
Drives: 2014 FRS
The engine is supported with a floor jack on the oil pan. The transmission is supported with a transmission jack.
The block of wood is to prevent the gap on the top from closing when prying the transmission back from the bottom. There are blocks of the same thickness on the bottom left and bottom right. The gap is even all the way around - it is pulled straight back.
The Following User Says Thank You to gkanga For This Useful Post:
Ultramaroon (03-13-2023)
Old 03-12-2023, 08:35 PM   #6
gkanga
Drives: 2014 FRS
Thanks, that's a good thought. I did try that once yesterday without any improvement but I had forgotten about that idea. Going back and forth a few times might help.
Old 03-12-2023, 09:42 PM   #7
soundman98
soundman98's Avatar
but if the engine isn't supported like ultra was saying, yanking harder really isn't the right answer
Opie (03-14-2023)
Old 03-12-2023, 09:45 PM   #8
gkanga
Drives: 2014 FRS
The engine is on a floor jack
Old 03-13-2023, 12:26 AM   #9
Ultramaroon
not playing cards
Ok, gotcha. Can you get it back together, or is it jammed?
If it goes together, and you're certain there isn't something else jamming the transmission, perhaps a couple smooth, "assertive" pulls will free it.
Old 03-13-2023, 12:53 AM   #10
gkanga
Drives: 2014 FRS
It does go back together. I tried pushing it back together and pulling it apart a few times. Maybe some progress, hard to tell. I'll mess with it some more tomorrow.
Old 03-13-2023, 01:05 AM   #11
Ultramaroon
not playing cards
Maybe spray some wd-40 in there, but only if you intend to pull apart the clutch to clean everything with brake cleaner or acetone.
Staying tuned.
Old 03-13-2023, 12:43 PM   #12
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
If the TOB is caught on the housing, you might push the clutch pedal in with your pieces of wood between the bellhousing and engine. Or work a pry bar behind the TOB.
Old 03-13-2023, 06:42 PM   #13
Grady
Grady's Avatar
Prying apart or forcing it together is not a good solution with a transmission. When you get the transmission loose the nose of the engine will dip down. Support the front of the engine. Take a look at everything else you may be missing something.
The Following User Says Thank You to Grady For This Useful Post:
Opie (03-14-2023)
Old 03-13-2023, 11:47 PM   #14
gkanga
Drives: 2014 FRS
The TOB moves freely. I can slide it back and forth with the top of the clutch fork easily. I can see it through the gap between the engine and transmission and it doesn't appear to be caught on anything.
Transmission removal 86league Engine, Exhaust, Transmission 7 12-10-2018 03:38 PM
Front seat removal woes, things I dealt with and you shoould be aware of.. OICU812 Cosmetic Modification (Interior/Exterior/Lighting) 11 04-01-2016 09:59 AM
Turbo Woes RedFR-s Forced Induction 38 10-14-2015 07:25 AM
Transmission selector shaft removal Nigelr32 DIY (Do-It-Yourself) Guides 0 12-29-2014 04:34 AM
More Woes for GM? White64Goat Other Vehicles & General Automotive Discussions 3 03-28-2014 10:23 PM
