Builder/Driver/Enthusiast
Drives: 2013 FR-S 6MT Turbo Firestorm
Turbo Woes
I've had just about every problem under the sun with this damn turbo. the fuel pump was a nightmare to get it (I'm not sure it's in properly), the car went into limp mode on the drive home from my tuner which I though was my pump failing. It wasn't the pump, one of the coolant lines over heated and blew spewing my coolant everywhere. engine overheated and cut, luckily no damage. Put on appropriate lines and no similar issues since.
The car is hesitating under load. I'm waiting to get a wideband installed so I can figure out if it's lean or rich, but I'm thinking starvation. I took it to a shop (way to frustrated to trust myself at this point) and they are saying pump and injectors are good and it's a tune issue. Driving home from a car show this week I had major hesitation and rough idle causing a stall. One of the vacuum lines failed causing a vacuum leak. I was hoping this was the main issue, but the vacuum leak is fixed and I'm still getting hesitation under load. I'm using a tune that was on this kit on another car that worked perfectly. I'm out of ideas at this point. I've got my tuner saying its mechanical and my shop saying its the tune. I did find a loose v-band, but its connecting the wastegate pipe to the waste gate, so it should have any impact on the AFR. I can't get at it with the tools I've got right now without taking some major parts off the car. http://www.ft86club.com/forums/showthread.php?t=92601 Found this thread, and I think my issue is identical but not sure what the tune changes were though. My tuner came highly recommended from other 86 owners running all kinds of boosted applications. Mine was tuned on a dyno. My car ran perfect with no symptoms this morning (ambient air was 15degC vs usual 30degC and I dull pulls to 120kmph WOT after about 10min of driving as opposed to merging on a freeway after about 20min of driving. Starting to think it could be heat related. Sorry for the long post, I'm looking to get as much insight as I can as I'm at the end of my rope with this project.
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig |
Drives: Sterling BRZ Ltd
This is one of those cases that's extremely hard to diag with out seeing it. My guess would be something mechanical throughing the tune off. It's often best to just get a second set of eyes on the car, see something your missing. Who did the initial install?
I did the original installation. I took it to the shop for the second look but they are pretty much at the same point as me. I have a buddy who's done FI before who's gunna help me look it over as well
Andy
You say the tune is from a previous car, are you sure you have the exact same setup? Brand and size of injector, fuel pump, MAP sensor that sort of thing.
| The Following User Says Thank You to mrk1 For This Useful Post: | RedFR-s (08-10-2015) |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Plus who knows if that tune worked out well for previous owner..probably blew his car up, thats why he sold the kit.
797Performance.com
Drives: Late 2014 Subaru BRZ
Can you please post the turbokit brand, The turbo model used and other really helpful information? Like complete mod list on the car.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
Drives: 93.5 supra t & prius
How could there be so many part failures? You need to address that first before you can start saying it's the tune. Furthermore you couldn't save up a little more money for a couple diagnostic tools to help see what's going on - afr gauge etc? This was going to be an expensive process so I suggest you be more generous with your money after you see all the mechanical issues are addressed. Was this your first big install of parts and why didn't the shop see these potential issues?
Bilge monkey
Drives: '13 BRZ, 82 starlet
button up all the half assed stuff,then get it tuned by a pro...
#9 | |
Here's the relevant parts list FA20 Club Turbo kit @ 7psi spring loaded BOV AEM Meth injection kit 50/50 mix AEM 5210 310lph fuel pump Stock injectors Perrin full exhaust Omni 3 bar MAP sensor Running on 94 octane
Andy
1977 Triumph Spitfire 1500 - New Project 2013 Firestorm FR-S 6MT Turbo - Sold 2013 Honda CBR 250 Repsol- Toy 2017 Toyota Tacoma - The Rig Last edited by RedFR-s; 08-11-2015 at 08:57 AM. |
#10 |
It was tuned by a highly recommended and respected tuner used by various performance shops in my area.
Andy
#11 |
Bilge monkey
#12 |
I know the previous owner well. He sold the kit as he is changing platforms for racing. He loved the kit while he had it.
Andy
#13 |
Thats pretty neat
Drives: LOADING......
What mixture % of water meth are you running? And how is it being triggered?
#14 | |
I'm not blaming my tune, I suggesting it as a possible cause. I was under no false pretenses that this would be expensive. I've bought a wideband and am awaiting shop time to get the bung installed. The coolant line failure I can't explain as the set-up was exactly what was used by the previous owner. I still have to get exact details from my shop on the vacuum line issue. This was my first big install and I have turned to this community to learn and ask for help, not be mocked and ridiculed. That isn't the point of these forums.
Andy
| Paint Chip Woes | onetime4 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 16 | 05-22-2015 06:37 PM |
| Engine woes | drew_kar | Issues | Warranty | Recalls / TSB | 8 | 02-16-2015 01:45 PM |
| Ebay log in woes | Trashed675 | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 09-03-2014 05:58 PM |
| More Woes for GM? | White64Goat | Other Vehicles & General Automotive Discussions | 3 | 03-28-2014 10:23 PM |
| APR GT Bumper woes | tech4pdx | Northwest | 14 | 08-31-2013 01:03 AM |
