Old 02-24-2023, 08:45 AM   #1
VancityBrz
VancityBrz's Avatar
Drives: Blue Hikari Brz
Spec-D Retrofit Retroquik kit does not work on Brz or Frs? Advice
I purchased the Retrofit Source Spec D kit for my Spec-D headlights and none of the holes or adjustments align. Do they not work for the frs or brz? I feel like I just wasted a bunch of money, the lens also feels very cheap and the bracket doesn't fit at all.
Anyone have any experience?
https://www.theretrofitsource.com/mo...ECD?quantity=1
VancityBrz is offline   Reply With Quote
Old 02-24-2023, 09:34 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
SPEC-D LIGHTS: Can vary, but the same. To ensure this kit will work on your housings; be sure to match up the template to the existing projector to ensure they're a match. The template can be seen below.
One review mentioned nursing washers etc to line it up better on a different platform. Universal fit is relying on spec D to make their assemblys the same
DIY - Spec D Headlight Retrofit LED Bar (Completely Reversible) Mr Mister DIY (Do-It-Yourself) Guides 10 02-01-2019 12:54 AM
Spec-D Headlights Retrofit? YamahaR86 Cosmetic Modification (Interior/Exterior/Lighting) 12 12-04-2015 02:34 PM
Spec D Headlights RetroFit Wyattkb Cosmetic Modification (Interior/Exterior/Lighting) 0 05-04-2015 12:15 AM
WTB: Stock Headlights w/ Retroquik or other Retrofit - maybe blacked out cdo221 Want-To-Buy Requests 0 01-28-2014 08:20 PM
Retroquik kit bixenon + functional led 9005 drl bulbs? eddieEndo Cosmetic Modification (Interior/Exterior/Lighting) 12 04-27-2013 06:06 AM
