Old 02-20-2023, 09:03 PM   #1
VancityBrz
VancityBrz's Avatar
Drives: Blue Hikari Brz
Performance Package STI Discontinued Brembo?
Hello, I'm in the process of installing Performance Package Brembo Brakes on a non-brembo BRZ and was told I wouldn't be able to purchase part number 26261FE000 caliper bracket / tie bar front
https://www.subarupartsdeal.com/part...6261fe000.html
That bracket is required for installing the front brakes but wasn't included when I purchased my PP Brembos.
I also tried speaking to a few Toyota dealers and was told they have no ETA and aren't sure if they will get them again Toyota part number SU003-06297 caliper bracket / tie bar front
https://ibb.co/6HjM1w5
https://ibb.co/b5mRvHr
https://ibb.co/BBnvx6z
I also tried purchasing them online but was told Subaru no longer makes the bracket. Is there a reason they stopped making the Brembo bracket but still sell the PP Brakes?
Is there any other option to use an alternative manufacturer or custom-make something?
Thank you for any help!
VancityBrz is offline   Reply With Quote
Old 02-21-2023, 10:13 AM   #2
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I had issues a few months back tracking down the dust shields for the Performance Package Brembos. They were listed as discontinued on all the US Subaru/Toyota parts sites. I was able to order them from Amayama. I believe you can get them from most other direct JDM parts sites as well.
Old 02-21-2023, 11:29 AM   #3
RedReplicant
Drives: None
I am kind of curious if it actually does anything other than reduce NVH and take up length on the bolt.
Before I had them in hand I assumed they were a bracket or were used to space the caliper somehow, which they are not.
RedReplicant is offline   Reply With Quote
Old 02-21-2023, 11:49 AM   #4
Tatsu333
Drives: 2020 BRZ Sport Tech RS
I think you're right on with them being just to reduce NVH.
FWIW, some 2nd gen BRZ folks have mounted the calipers to the new aluminum knuckles without that piece using shorter STI bolts, and they seem to work fine. Seeing as that's apparently the way they're mounted on the STI, it makes sense.
Only comment I've seen from a couple posts is that they might be a bit noisy, which would suggest your thinking is right. EDIT: I'd guess the STI doesn't have the issue because of the front drive axle stuff being attached being enough of a damper that it doesn't need that piece.
FYI - the part number for the STI bolts is 901120103.
Last edited by Tatsu333; 02-23-2023 at 06:13 PM. Reason: Added PN for bolts and comment RE: STI
Tatsu333 is offline   Reply With Quote
The Following User Says Thank You to Tatsu333 For This Useful Post:
RedReplicant (02-21-2023)
Old 02-21-2023, 03:37 PM   #5
Grady
Grady's Avatar
eBay, Junk yard? A seller on eBay has them, a little pricey but better than having a set of brakes sitting in your garage.
Old 03-19-2023, 11:07 AM   #6
Derka
Drives: 2015 frs
I ran these on my 22 brz as you described. No issues
Derka is offline   Reply With Quote
The Following User Says Thank You to Derka For This Useful Post:
Tatsu333 (03-19-2023)
SOLD: BRZ Performance Package Brembo Brakes Mike_ZN6 Brakes, Suspension, Chassis 2 01-25-2022 12:29 AM
Tip for removing Performance Package Brembo calipers haohmaru Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 01-06-2022 12:39 PM
WTB Performance Package Brembo Calipers and Brackets Sachmet43 Want-To-Buy Requests 2 06-04-2021 12:08 AM
Part number for brembo rotors on oem performance package sroby Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-30-2020 02:03 PM
FT86SF's Performance Package Brembo Info Thread FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 08-13-2019 04:11 AM
