Drives: Red 2024 GR86 Trueno
Tip for removing Performance Package Brembo calipers
Removal is pretty standard except for this bracket. The two bolts are captive so you'll need to remove them evenly otherwise they will bind inside the bracket.
![]() Sent from my iPad using Tapatalk |
| The Following 10 Users Say Thank You to haohmaru For This Useful Post: | bcj (08-17-2021), CrowsFeast (08-18-2021), DAEMANO (08-17-2021), Dzmitry (07-30-2021), FrickingReallySlow (08-18-2021), JohnH (08-17-2021), Mike_ZN6 (07-24-2021), MJones_RB (08-20-2021), Ohio Enthusiast (08-18-2021), x808drifter (07-24-2021) |
Professional wrench
Drives: 2020 BRZ ST RS
thanks, thats a good tip. could save some headaches
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align. Gruppe-S UEL header/overpipe Wayne Rom Stg 2+ tune 225/45VR17 RT660s |
Drives: 2013 BRZ Sport-Tech
I take it this post was made when you ran out of expletives; in order to save others from spouting the same expletives.
| The Following User Says Thank You to CrowsFeast For This Useful Post: | Lantanafrs2 (08-18-2021) |
| The Following User Says Thank You to haohmaru For This Useful Post: | CrowsFeast (08-19-2021) |
Drives: BRZ ts
That happened on my last car’s turbo switching the downpipe for inspections. After drilling it out, my brother broke my tap off in it. Drilling out old bolt was infinitely easier than removing that.
| The Following User Says Thank You to dpfarr For This Useful Post: | CrowsFeast (08-19-2021) |
Bringing this one back from the dead a bit but seeing those bolts are 19mm and after a few hours of banging on the rachet I've gotten one of the bolts loose. What am I doing wrong?
Drives: Crapcan
More torque. They shouldn't be that tight, maybe like 40-45ftlb. You may have some corrosion hampering your efforts. I'd also make sure you use a 6pt socket so you don't round off the edges.
Thanks and using a socket with a poly hammer, any chance these would be locktited? From what I've seen spec is like 90lbs, same as the wheels but I've a lot more space with a breaker bar for those.
#9 | |
Drives: Crapcan
I'd use a breaker bar with a 3in extension and a 6pt socket to keep it from slipping.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | timurrrr (01-24-2022) |
#10 |
#11 |
Drives: Crapcan
Use longer extension. Just be careful you don't allow the socket to rock on the head or you may round off the bolt, or bust your knuckles.
#12 | |
Will give that a go tomorrow but as I'm remembering it I didn't have room for much of an extension. Knuckles already busted anyway |
#13 | |
Drives: Crapcan
#14 |
Ok so the trick for me was jacking the car higher and using the floor jack handle around the rachet for more leverage (apparently don't have 1/2" sockets and my long handled torque wrench wouldn't fit in the space with the 3/8-1/2 adapter). So I got that bracket off....but the caliper still won't come off....it'll rotate with the rotor maybe 10-15 degrees but that's about it. Didn't want to wail on it with a hammer if I was missing something else, but is there something more than that bracket with the two 19mm bolts keeping it on? I'd say there's a good chance it's never been off (car only has 20k on it and still on original pads/rotors as far as I know).
| WTB Performance Package Brembo Calipers and Brackets | Sachmet43 | Want-To-Buy Requests | 2 | 06-04-2021 12:08 AM |
| removing rotors with Performance Package Brembo calipers | gshopper | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 11-17-2020 11:13 PM |
| SOLD: Performance Package Brembo Brakes. NEED TO MOVE! | Desain2137 | Brakes, Suspension, Chassis | 2 | 04-12-2020 01:11 AM |
| Part number for brembo rotors on oem performance package | sroby | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 01-30-2020 02:03 PM |
| FT86SF's Performance Package Brembo Info Thread | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 119 | 08-13-2019 04:11 AM |
