Old 02-19-2023, 02:48 PM   #1
0helloworld0
Drives: 2020 toyota 86
Unhappy 2020 Toyota 86 Engine Knock
Hello!
So I bought a Brand new 2020 Toyota 86 (Automatic). I have 18k miles so far and the engine started to knock
The car is with the dealer but they are struggling to diagnose it...
First Time I told them about this issue they could not replicate it, so I had to take a video to prove its happening.
I left it with them for a full day to try after a cold start (seems like this is when it's mostly happening) and they finally noticed it. but it's not consistent and it goes away after a while... they told me they will reach out to Toyota to see if other people have reported the same problem but according to them, it's hard to diagnose since it's not consistent...
I have seen many threads with the same issue (but mostly older models 2013). looks like it might be the Vaccum pump? (best-case scenario).
Any idea what's going on?
I will keep you updated.
Thanks.
0helloworld0 is offline   Reply With Quote
Old 02-19-2023, 08:12 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That’s not rod knock. There is an odd noise, hard to tell. Being automatic check vacuum pump on rear of passenger side head.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
Lantanafrs2 (02-19-2023), Ultramaroon (02-20-2023), x808drifter (02-21-2023)
Old 02-20-2023, 01:49 AM   #3
gpvecchi
gpvecchi's Avatar
Mine did a similar noise when cold. The v belt was dry. I'm equipped with HKS V Belt and laluminium pulleys and bearings.
Edit: link to video
https://files.fm/u/jgstwxmvh
It was fixed using a Molykote specific V Belt grease
gpvecchi is offline   Reply With Quote
The Following User Says Thank You to gpvecchi For This Useful Post:
bcj (02-20-2023)
Old 02-20-2023, 05:38 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1 Vacuum pump.
brz, engine, knock, toyota 86
Engine knock!! tcarnes08 Forced Induction 4 02-07-2023 01:58 AM
Brief engine knock/cold engine/first couple accelerations@2.8-3krpm Reyanth Issues | Warranty | Recalls / TSB 5 11-15-2020 03:32 PM
2020 Toyota 86 Hakone Edition at Torrance Toyota MJones_RB Southern California 4 02-08-2020 01:29 PM
Engine knock Zentec Engine, Exhaust, Transmission 22 09-05-2017 04:46 PM
Engine knock zman Issues | Warranty | Recalls / TSB 76 02-22-2016 11:28 PM
