Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Brakes, Suspension, Chassis
Old 02-16-2023, 06:13 PM   #1
SakeBomb Garage
FT86Club Official Vendor
Drives: BRZ/FRS
Sakebomb Garage Spring Cleaning Deals!
Spring is right around the corner, which means we have a bunch of new inventory on it's way to us for the upcoming track season. This means now is the perfect opporunity for us to give out killer deals on some of our on the shelf inventory, and who better to benefit from this than you?
BRZ/FR-S/ GT86 OHLINS ROAD AND TRACK KITS
If you're looking to upgrade your current suspension, there's really no better option than Ohlins. Utilizing their patented DFV damper technology, they've been on top of the suspension game for decades and that same experience and expertise is exactly what you get with this kit.
We're giving a special deal to people on ft86club for this kit! Buy an Ohlins Road and Track kit, get $250 (!!!!!) in store credit that can be used for any purchase on out site for the following 90 days! This can held you get some sway bars, end links, bushing kits, brakes, exhausts, anything you can possibly need. If it isn't on our site, shoot us an email and there's a good chance we can get it for you!*
Ohlins Road and Track Coilovers
Ohlins has introduced the final step in their automotive design process, the Road & Track Series.
The 30 year long tradition of high-end racing and state-of-the-art suspension technology is now available for daily driven street cars all over the world. Their focus has been clear from the beginning, superior road handling and feel without sacrificing the drive-ability or comfort of you street driven automobile.
They have also lightened the weight by replacing a majority of parts with aluminum. On top of that, Ohlins has also put their shocks through a vast corrosion test process according to ISO 9227 procedures. The end result is a 2-year warranty on all of their products - worldwide.
Features:
- DFV (Dual Flow Valve)
- Corrosion salt spray tested to ISO 9227 - 2 year warranty
- Single bleed/Preloaded spring adjusters
- Fully re-buildable w/dust-covers
- Spring Rate: Front: 50 N/mm Rear: 50 N/mm
Front (McPherson Strut):
- Single bleed adjuster
- Spring preload adjuster (20 mm lower than standard)
- Coil Springs
- Dustcovers
Rear (Conventional Shock Absorber):
- Separate spring preload adjuster (20 mm lower than standard)
- Coil Springs
- Dustcovers
Sakebomb Garage Designed Wilwood Sport Brake Kit
Our Wilwood Sport Brake Kit is the best bang for your buck braking upgrade option. Utilizing Wilwood superlite calipers, you can drastically improve your braking capabilties without hurting your pockets.
What it includes:
Wilwood Forged Superlight Calipers
“Dual sided” 6061 Billet Caliper Mounting Brackets
DOT Approved Stainless Steel Brake Lines with dirt/abrasion sleeves
Full Pictorial Installation Guide
Some info on the forged Superlite Calipers:
Ultra-Lightweight Forged Aluminum Construction
Durable Hard Anodized Finish
Stainless Steel 4 Piston Design
20mm Thick Brake Pad for Caliper Heat Transfer
Thick Pads Provide Extremely Long Life and Reduce Frequency of Replacement
These kits are on sale for $650 for Gray calipers, and $810 for either Red or Black calipers. Normally priced at $850 for Gray and $1,010 for Red or Black, this is a killer deal. Supplies are pretty limited on these, so order these soon!
FPSpec Hood Dampers
Our Custom Hood Damper kits are carefully designed for each specific OEM hood application. The high-end damper and locking ball join/cup mount allows for smooth movement opening and closing the hood. Installation is very simple with the included instructions and labeled components. This is a great way to update and improve both the functionality and looks of your modified engine bay!
New sale price is $70 for standard body hood dampers, and $120 for carbon fiber body.
Sold in pairs. One kit will allow you to mount a damper on each side of your engine bay.
Please note that this kit is designed to work with stock weight hoods and may behave oddly with heavier or lighter aftermarket replacements.
ALSO NEW SALE PRICES!
$5 off of our stainless steel clutch lines
$20 off brake lines
*Use code STORECREDIT250 at checkout and you will be sent a $250 dollar gift card valid for 90 days after being sent. Giftcards will be sent no more than 3 days after initial purchase. For international inquires, please email us directly at info@sakebombgarage.com so we can give you accurate shipping quotes.
SakeBomb Garage is offline   Reply With Quote
Garage Cleaning Wheel Spacer SOLD kinghurl Wheels and Tires 3 01-04-2022 09:34 PM
SakeBomb Garage: WILWOOD TRACK-DAY BRAKE SYSTEM SakeBomb Garage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 07-22-2019 10:36 PM
SakeBomb Garage: Track Day BBK Kit for the BRZ/FT86 SakeBomb Garage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-23-2019 09:20 PM
SakeBomb Garage: Track Day BBK Kit for the BRZ/FT86 SakeBomb Garage Brakes, Suspension, Chassis 6 05-23-2019 09:19 PM
Cleaning my garage lots of parts! ZOMFGAARON Miscellaneous 16 01-06-2016 05:26 PM
