Old 09-26-2018, 04:51 PM   #1
SakeBomb Garage
FT86Club Official Vendor
Drives: BRZ/FRS
SakeBomb Garage: Track Day BBK Kit for the BRZ/FT86
Introducing the NEW SakeBomb Garage Wilwood Track Day Kit for the BRZ/FT86!
Building on the success of our similar brake kits for our SCCA and NASA winning S2000 and RX7's. We produced this brake kit with the intention of bring race engineering to the broader motorsports market with an affordable but potent brake solution. We call this our endurance Track-Day brake kit! We have designed an affordable, light weight, and heavy duty brake system, which has great thermal capacity with extremely thick (20mm) pads, making it both a great thermal barrier between the caliper and rotor (preventing boiling fluid) while also giving a great value with so much pad to go through vs the other options out there. A true racing caliper, directional curved vanes in an affordable package with wide pad selection make this BBK a no brainier on the track or street!
Our new Wilwood Track-Day Brake System, for the BRZ is available with introductory pricing for a limited time! We have put together a competition inspired brake system, utilizing lightweight, high-efficiency components. We're sure you'll agree this "Light-Track" BBK a fantastic option for high performance braking, at fantastic price points.
Ultra-lightweight Forged Wilwood Calipers with stainless steel pistons and high temp seals, paired with your choice of our light-track two-piece SBG 325x32mm Premium Rotors (32 directional curved vane) This kit utilizes the same quick-change 20mm thick pads as our AP Racing Competition Kit, and the same rotor size, providing you with amazing bang for buck.
The benefits of the Wilwood caliper are quite clear, with almost 3lbs of unsprung weight saved at each caliper when compared to other big brake kits, while still retaining excellent caliper stiffness. Put mass into what matters... the rotor, not the caliper!
This is the perfect package for customers looking for the maximum bang for their buck when it comes to braking performance. These brake calipers utilize one of the most common racing pad shapes, and accommodate a full 20mm thick pad. Not only does this provide additional thermal insulation for the calipers, but with a massive 50mm of useable anulus, wear on the face of the rotors, as well as the pads, is greatly reduced compared to smaller profile brake kits. This results in much more robust lifespan for both the rotors and brake pads, and maximizes your dollar per braking compound/use.
Our Package Includes:
  • Wilwood Forged Superlight Calipers (hard anodized or powdercoat options available)
  • SBG 6061 Billet Caliper Mounting Brackets
  • SBG 325x32mm Solid Mount Premium Brake Rotors [B]
    *]SBG Designed Race Grade Aluminum Rotor Hats
  • SBG DOT Approved Stainless Steel Brake Lines with dirt/abrasion sleeves
  • Full Pictorial Installation Guide
This kit has everything you need to overhaul your aging, undersized stock brake system. From stock cars to high horsepower builds, this brake setup is a fantastic match with outstanding braking performance that will not break the bank.
Wilwood Forged Superlight Calipers:
  • Ultra-Lightweight Forged Aluminum Construction
  • Durable Hard Anodized Finish (optional powdercoat available)
  • Stainless Steel 4 Piston Design
  • 20mm Thick Brake Pad for Caliper Heat Transfer
  • Thick Pads Provide Extremely Long Life and Reduce Frequency of Replacement (cost effective for track use)
  • DOT Rated SakeBomb Stainless Lines included!
SBG Brake Rotor Features:
  • Endurance Sized 325mm x 32mm High-Performance Rotor
  • Light-Weight 2-piece Brake Hats
  • SBG Rotors feature 32 Directional Curved Vanes
  • Proprietary High Temperature Alloy Rings
  • SBG Slot Pattern engineered to increase pad bite,
  • Race Grade Hard Anodized Aluminum Rotor Hats
See Product page for more details!
Click here.
Feel free to discuss below or if you have any questions.
SakeBomb Garage
Last edited by SakeBomb Garage; 10-16-2018 at 03:25 PM. Reason: Editing brake options
SakeBomb Garage is offline
Old 09-26-2018, 05:31 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
- Worth providing brake clearance template, eg. attaching to OP post or link in url to download of one, if not list confirmed fitment for some popular wheel models/sizes/offsets;
- tell what is resulting brake bias with this (if used with your listed as compatible rear SBG BBK kit or if with OEM rear brakes);
- link in this pad also pdf of brake pads shapes used (seen on linked product page, but won't hurt here too);
- if this is track only kit, or if it also has some daily driving friendly features (eg. dustboots, optional solid brake disks, to lessen corrosion issues in winter-salt environment);
- if there are backing plates that allow connecting of airducts
- warranty policy / rehauling services offered
churchx is offline
Old 09-27-2018, 11:29 PM   #3
86TOYO2k17
Drives: 2017 toyota 86
What is the total weight of the kit per corner and or each component. Wondering how this stacks up with the Wilwood wrx kit that drops 16lbs a corner. I’m sure this is heavier but with much more performance. Would still be awesome to save 10+ lbs a corner and get the performance of the BBK.
86TOYO2k17 is offline
Old 09-28-2018, 01:01 AM   #4
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
In for this (or at least piston sizes so someone here can do the math)
finch1750 is offline
Old 09-28-2018, 05:44 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
finch1750: are piston sizes alone sufficient to calculate bias, if one doesn't know pad area & it's distance from rotating center?
churchx is offline
Old 09-29-2018, 01:49 PM   #6
finch1750
finch1750's Avatar
Most of the the other calculations that have been done on here have not gone that far into detail (usually assumed they are same as stock). But you could find the info on pad height based on the info provided already. The calculation sheet people have linked in the past didn't have anything about distance from rotating center so didn't know that was part of it. I'm kinda a newb, so just learning based on prior bbk threads basically.
http://www.tceperformanceproducts.com/bias-calculator/
Old 09-29-2018, 04:09 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Be nice if they answered. There are 3 calipers I could find that these could be that support a 1.25 rotor with a 20mm pad. Piston diameters of 1.62, 1.38, and 1.25 If I had to guess, it is likely the 1.62 setup. According to the pointmeby blog that would move bias forward about half a percent. Not bad.
I always find it off putting when a vendor tries to compare their product in a skewed way as superior against a known one that works well. Just sell your product.
NoHaveMSG is offline
Old 09-29-2018, 05:39 PM   #8
ls1ac
ls1ac's Avatar
I have been using this setup for 5yr and can say nothing but great. We use the BRZ as kind of a backup car at the track. Second time out we were turning the stock rotors cherry red, as in bright sunny day it was so obvious the corner workers black flagged us.
These brakes will stand this little car on its nose. My son took a couple of SCCA boys for a ride and they all were shaking there heads in amassment for the stopping power for such a heavy car.
We use the 20 series pads for street and the 30 for the track. Never had a problem. The tires for the street are Advan AD 08 and for the track either Hoosiers or the AD888 depending on temperature.
Balance has never been an issue either, with track pads in stock calipers in the rear.
In addition these calipers are easy to inspect and simple to change pads.
ls1ac is offline
Old 09-30-2018, 02:22 AM   #9
Turbo
Drives: FR-S Turbo
um - no.
If those are the calipers they used, it would make this system heavily front biased.
I haven't done the detailed math, but likely up from the OEM 69.7% front bias to something that is 75%+
Turbo is offline
Old 09-30-2018, 06:39 AM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by Turbo View Post
um - no.
The chart I have seen on this using the 4 pot caliper with the 1.62 pistons and a 12 in rotor was a 69.8 front bias. Can't imagine the front bias with a 325mm rotor being much worse considering we don't know what the distance from center is of the caliper. I seem to remember some of the other kits, maybe it was RR, the caliper distance was the same even with the slightly larger rotor
https://www.pointmeby.com/2016/09/24...z-frs-gt86-86/
Old 09-30-2018, 12:00 PM   #11
Turbo
Drives: FR-S Turbo
That chart was for a 4-piston caliper, and much smaller rotor.
The caliper you quoted is 6 piston, with basically 20% more piston surface area AND is being used with a larger rotor. If that is the caliper they are using, it is a terrible choice as a front-only upgrade.
Turbo is offline
Old 09-30-2018, 12:38 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The Wilwood 4r is right below OEM on the chart.
Sent from my Moto E (4) Plus using Tapatalk
Old 09-30-2018, 12:45 PM   #13
wreckedrex
Drives: 2016 BRZ Limited
Per the description in the OP: "Stainless Steel 4 Piston Design"
wreckedrex is offline
Old 09-30-2018, 01:41 PM   #14
Turbo
Drives: FR-S Turbo
My comments are quite clearly directed at NoHaveMSG who speculated using a 6 piston caliper with "piston diameters of 1.62, 1.38, and 1.25 If I had to guess......"
Turbo is offline
SakeBomb Garage: Track Day BBK Kit for the BRZ/FT86 SakeBomb Garage Brakes, Suspension, Chassis 6 05-23-2019 09:19 PM
FT86 Track School Group Buy Frost CANADA 98 06-10-2018 10:50 PM
CounterSpace Garage Customer Appreciation- Track day entry giveaways for 6/30 at SoWS CSG Mike Southern California 7 06-27-2013 11:13 PM
CounterSpace Garage Customer Appreciation- Track day entry giveaways for 6/30 at SoWS CSG Mike Tracking / Autocross / HPDE / Drifting 22 06-26-2013 06:55 PM
Track day giveaway by CounterSpace Garage CSG Mike Southern California 43 04-19-2013 11:12 AM
