Old 02-16-2023, 02:54 PM   #1
nlenn
Drives: 2019 Subaru BRZ
Bricked ECU With OFT?
I previously had stage 2+ OFT tune on my 2019 brz. Today I tried to flash to the original file. I've switched the tune using the OFT a decent number of times and all things seemed normal until it was about to finish writing. I received an error on the tablet:
An error occurred while writing the ECU. Check cable connections, ignition switch position, then try again. Error code: 10010
I kept the tablet and cable completely still while it was writing.
After this I checked cable connection; all seemed good there. Assumed maybe it was a fluke and tried flash back to the original again. This time it didn't even begin the write operation. I was receiving the 10010 error before any writing happened. At this point I tried seeing if the OFT could read any data and got nothing. Can't see live diagnostic info, can't get ECU info, nothing. After this I unplugged OFT and tried to start the car. No crank, car won't start.
Before flashing the car had been running for ~30 min so I'm thinking it was unlikely a problem w the battery being low. I also disconnected the battery for about an hour and tried to start again, didn't work. When ignition is on I see a 'engine coolant high temperature' warning? Honestly no idea what to do from here. I'm thinking I'm screwed but I figured I'd post here to see if anyone have ideas before I start spending money to fix this issue.
nlenn is offline   Reply With Quote
Old 02-17-2023, 10:15 AM   #2
Have you actually checked the battery power yet? Can't just assume it is fine need to verify as the first step.
Old 02-17-2023, 10:39 AM   #3
nlenn
Thanks for the reply - but yeah before disconnecting the battery I checked with voltmeter and tried to flash again. I should've included the in the post my b
The Following 2 Users Say Thank You to nlenn For This Useful Post:
Tcoat (02-17-2023), x808drifter (02-19-2023)
Old 02-17-2023, 10:44 AM   #4
So so many skip that step!
Sorry tuning is out of my pay grade so I can't help any more.
@AussieBRZ any words of wisdom?
Old 02-17-2023, 11:11 AM   #5
tomm.brz
Drives: brz 2017 hksv2
Steve has answered about this in the last, like here https://www.ft86club.com/forums/showthread.php?t=98810
your best bet is to try what he says (also dig in other posts of his)
and also contact openflash support
Old 02-20-2023, 04:42 AM   #6
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Check volts is over 12v
Ensure ignition full on , not just accessory
See if oft will read idagnosic data or ECU info, that will check connection
I'd say it cable issue or obd port bad connection
Try flashing back stock tune is original tune from oft
https://support.openflashtablet.com/...t-oftcode-list
AussieBRZ is offline   Reply With Quote
Anyone have a OFT V2 that's bricked DJjoey0812 Software Tuning 1 05-27-2022 07:18 PM
Possible bricked OFT? dar3d3vil Software Tuning 7 08-18-2017 07:55 PM
Bricked ECU? FirestormFlex Software Tuning 8 03-14-2016 09:20 AM
Who has Bricked an ECU Toyota John Software Tuning 5 03-02-2015 10:10 PM
Need Bricked BRZ 86 ECU steve99 Software Tuning 0 10-25-2014 06:09 PM
