Old 02-13-2023, 09:31 AM   #1
Tjaen6
Tjae
Tjaen6's Avatar
Drives: 2014 Scion FRS Black
Sluggish throttle response at 3K RPMS
So I have a 2014 Scion FRS . The engine blew and I engines swapped it with a 2013 engine . After all is said and done I’ve been doing some test driving and I receive a very sluggish throttle response at 3k RPMs . Not the usual issue for lack of hp. It’s more like I hit the gas’s ans the Rpms will rise past 3k with no gain in speed and drop back down to 3k and then go. It’s like a “sluggish” response . I’m going to take it to a shop to have it looked at but my thought is that maybe it has something to do with tuning or transmission .
Any thoughts ? Car has no other modifications other than 2013 engine swap(10k Miles) and a cam plate for that oil leak a few of us has dealt with .
Tjaen6 is offline   Reply With Quote
Old 02-13-2023, 10:36 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
AT or MT?
If auto.
Torque Converter?
Trans?
If manual.
Clutch slipping.
Old 02-13-2023, 10:42 AM   #3
nripinbabu@gmail.com
Drives: brz
There is a very popular cat delete and oft tune to overcome the torque dip
nripinbabu@gmail.com is offline   Reply With Quote
Old 02-13-2023, 11:19 AM   #4
gav_abr
gav_abr's Avatar
Drives: 2018 Subaru BRZ Sport-tech RS
Sounds like this probably isn't the torque dip given that OP had the car before the engine blew and it didn't have the described problem at that point. Also the torque dip is noticeable but it's not as bad as how it's described here.
gav_abr is offline   Reply With Quote
Old 02-13-2023, 11:22 AM   #5
Tjaen6
Tjae
Tjaen6's Avatar
Originally Posted by x808drifter View Post
AT or MT?
If auto.
Torque Converter?
Trans?
If manual.
Clutch slipping.
It is a Manual transmission. Called shop and they said it could be a possible vacuum leak as well. But the clutch makes sense honestly.
Old 02-13-2023, 11:24 AM   #6
Tjaen6
Tjae
Tjaen6's Avatar
Not talking about torque dip, tbh I think it is a result of clutch slipping maybe from misalignment. When I take it to the shop they’ll confirm.
Old 02-13-2023, 11:54 AM   #7
Tjaen6
Tjae
Tjaen6's Avatar
Just took it to the shop, I pushed it and funny enough it wasn’t really happening. Seems like a inconsistent issue
Old 02-13-2023, 12:06 PM   #8
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
After unplugging the battery for any reason, the computers have to re-learn how all the sensors are responding.
Takes about 200 miles to get a handle on that so it plays safe with computed signal levels til then.
Very sluggish throttle response at 3k rpm Hayer_86 Issues | Warranty | Recalls / TSB 10 01-15-2021 01:21 PM
OFT v4.03 throttle response Tristor Software Tuning 29 09-22-2019 04:51 PM
OFT throttle response MyGT86Yas Software Tuning 6 02-26-2018 05:44 AM
Throttle Response CamryDS Northern California 27 03-31-2015 03:35 AM
Poor response/power below ~2500 rpms? New car. Formula Vee Issues | Warranty | Recalls / TSB 21 02-16-2014 02:33 PM
