Old 02-11-2023, 02:08 PM   #1
RedReplicant
Drives: None
SOLD Stoptech Front 355mm / Rear 345mm BBKs
SOLD
Swapped to 17" wheels and PP brakes for tire choice and classing reasons so I am selling my old BBK as the front kit won't fit under basically any off the shelf 17" wheel.
I've test fit the rear 345 under a 17x9 +35 TC105 and 17x9.5 EC7R, both have clearance for days so I am guessing it'd fit nearly any PP clearing 17" wheel.
Pads are CSG C2 with a significant amount of pad depth left front and rear. Rotors are good and have the usual surface cracking, no lip, etc. I very strongly recommend getting new brake lines, but they are included. All required bolts are included too.
They calipers are difficult to clean without damaging the paint so I didn't try real hard as soon as I realized simple green and brake cleaner were corrosive to it. The black marks on the front calipers are from tire rubber getting stuck between the wheel/caliper on track. Two dust boots in one of the front calipers got a bit crispy and are cracked/torn.
Piston sizes are 38mm / 34mm front and 38mm rear
Dust boots:
https://www.zeckhausen.com/catalog/p...roducts_id=422
https://www.zeckhausen.com/catalog/p...roducts_id=210
Asking Prices
Front Kit: $x
Rear Kit: $x
Both Kits: $x
With respect to shipping - it'd be roughly 115lb and 36" x 16" x 16" for both kits in one box. Might be cheaper / easier to separate into two boxes.
RedReplicant is offline
Old 02-20-2023, 06:34 PM   #2
RedReplicant
Drives: None
Anyone want these things? Make me an offer
Old 02-24-2023, 05:29 PM   #3
RedReplicant
Drives: None
Price drop
Old 02-24-2023, 05:54 PM   #4
fryfun
Drives: 2014 Subaru BRZ DGM Limited
I want this so bad, but getting this means getting a new set of wheels and tires as well. $$$
fryfun is offline
The Following User Says Thank You to fryfun For This Useful Post:
RedReplicant (02-25-2023)
Old 02-24-2023, 06:12 PM   #5
Teseo
Drives: frs
For track duty or hardparker?
Teseo is offline
Old 02-25-2023, 02:15 AM   #6
mcbat68
Drives: 2022 White BRZ manual
this is such a good deal. You're not going to find a better BBK for this price. The C2 pads are superb as well.
mcbat68 is offline
The Following User Says Thank You to mcbat68 For This Useful Post:
Old 02-25-2023, 08:06 AM   #7
fryfun
Both. Mostly concerned about winter. My summer wheels and tires can clear this kit. But winter oem wheels can’t.
fryfun is offline
Old 02-25-2023, 03:17 PM   #8
RedReplicant
Drives: None
Yeah, the 18" constraint is hard to stomach but it is a great kit. There are SOME 17" wheels that fit, but usually they require the combination of the right spacers to move the wheel barrel widest spot relative to the caliper.
This is behind my 17x9.5 EC7R without any spacers, would probably BARELY clear with the right spacer size... but it'd also really not end well if you ovaled a wheel lol.
Old 02-27-2023, 10:18 PM   #9
RedReplicant
Drives: None
Sold
StopTech ST-40 328mm and 355mm Big Brake Kit Sale! Xero-Limit Brakes, Suspension, Chassis 1 04-10-2019 08:40 AM
Stoptech 355mm BBK D K Brakes, Suspension, Chassis 3 05-15-2018 04:44 PM
Almost brand new Stoptech 355mm BBK D K Brakes, Suspension, Chassis 21 06-15-2016 10:43 PM
FS- Stoptech BBK 355mm Rickg87 Brakes, Suspension, Chassis 11 04-23-2015 08:37 PM
FS- Stoptech BBK 355mm Rickg87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-31-2015 05:54 PM
